STM32MP13 Discovery kits - Starter Package
This article shows how to start up a STM32MP135x-DK Discovery kit More info green.png (flexible and complete development platform for the STM32MP13x lines More info.png ). It is valid for the STM32MP135F-DK Discovery kits: the part numbers are specified in the STM32MP13 microprocessor part numbers article.
1. Starter Package content[edit | edit source]
If you are already familiar with the Starter Package for the STM32MPU Embedded Software distribution, the fast links to essential commands might be of interest.
  • the software image for the STM32MPU Embedded Software distribution, which includes:
    • the binaries for the OpenSTLinux distribution
    • one or more firmware example(s) for the STM32Cube MPU Package
  • the (STM32CubeProgrammer) tool to install this image on the STM32MP135F-DK Discovery kit
Components of the Starter Package
2. Starter Package step-by-step overview[edit | edit source]
The steps to get the STM32MP135x-DK Discovery kit More info green.png up and running, are:
Checking the material
Assembling the board
Installing the tools
Downloading the image and flashing it on the board
Booting the board
3. Checking the material[edit | edit source]
Mandatory
Optional
Optional, more devices and extension boards might be plugged to the STM32MP135x-DKx Discovery kit thanks to expansion connectors such as:
  • the GPIO expansion connector
The following figure shows the optional material (not included in STM32MP135x-DK Discovery kit More info green.png package), that is used with this Starter Package.
Recommended material for this Starter Package
4. Assembling the board[edit | edit source]
Please note that the STM32MP135x-DK Discovery kit More info green.png includes the MB1723 camera module with its flat cable but neither USB cable nor USB charger is provided.
Position Description
1 MB1635 motherboard
2 MB1723 camera module
3 Camera module flat cable
STM32MP135x-DKx Discovery kit assembled
STM32MP135F-DK Discovery kit shown here (picture not contractual)
5. Installing the tools[edit | edit source]
5.1. Installing the STM32CubeProgrammer tool[edit | edit source]
Download
Version v2.10.A01
  • Browse SetupSTM32CubeProgrammer link and follow instructions to download the package, you need a myST account.
PC $>unzip en.stm32cubeprog.zip
Installation
$> ./SetupSTM32CubeProgrammer-2.9.0.linux
User manual
Detailed release note
5.2. Preparing the USB serial link for flashing[edit | edit source]
PC $> sudo apt-get install libusb-1.0-0
PC $> cd <your STM32CubeProgrammer install directory>/Drivers/rules
PC $> sudo cp *.* /etc/udev/rules.d/
  • For Windows host PC:
6. Downloading the image and flashing it on the board[edit | edit source]
6.1. Image download[edit | edit source]
  • The STM32MP1 image (binaries) is delivered through one tarball file named
    • FLASH-stm32mp13-disco-openstlinux-5.10-dunfell-mp13-21-11-30.tar.xz for STM32MP135x-DK More info green.png
  • Download and install the STM32MP1 image (binaries):
STM32MP1 Starter Package image - STM32MP13-Ecosystem-v3.1.0.ALPHA release
Download
If you didn't retrieve yet the file FLASH-stm32mp13-disco-openstlinux-5.10-dunfell-mp13-21-11-30.tar.xz, please follow instructions on the downloading instructions page.
Installation
$ cd <working directory path>/Starter-Package
  • Download the tarball file in this directory
  • Uncompress the tarball file to get the binaries for the different partitions of the image, and the Flash layout files:
$ tar xvf FLASH-stm32mp13-disco-openstlinux-5.10-dunfell-mp13-21-11-30.tar.xz
Release note
Details of the content of this software package are available in the associated STM32MP13 ecosystem release note.
Archive box.png If you are interested in older releases, please have a look into the section Archives
  • The binaries and the Flash layout files are in the <Starter Package installation directory>/stm32mp13-disco-openstlinux-5.10-dunfell-mp13-21-11-30/images/stm32mp13-disco/ directory:
stm32mp13-disco
├── arm-trusted-firmware                       TF-A binaries for FSBL partitions and supported boot chains
│   ├── tf-a-stm32mp135f-dk-sdcard.stm32       TF-A binary for FSBL partition (microSD card boot device) for STM32MP135F-DK → STM32MP13 Discovery kits
│   ├── tf-a-stm32mp135f-dk-uart.stm32         TF-A binary for uart serial boot mode (STM32CubeProgrammer) for STM32MP135F-DK → STM32MP13 Evaluation boards
│   └── tf-a-stm32mp135f-dk-usb.stm32          TF-A binary for usb serial boot mode (STM32CubeProgrammer) for STM32MP135F-DK → STM32MP13 Discovery kits
├── fip                                        FIP binaries for FIP partitions and supported boot chains
│   └── fip-stm32mp135f-dk-optee.bin           FIP binary for FIP partition (optee boot chain) for STM32MP135F-DK → STM32MP13 Discovery kits
├── flashlayout_st-image-weston                                 Flash layout files (description of the partitions) for the supported boot chains on supported boot devices and boards
│   └── optee                                                   Flash layout files for optee boot chain
│       └── FlashLayout_sdcard_stm32mp135f-dk-optee.tsv         microSD card boot device for STM32MP135F-DK → STM32MP13 Discovery kits
├── kernel
│   └── config-5.10.61                              Kernel configuration file used to build kernel binaries
├── scripts
│   └── create_sdcard_from_flashlayout.sh
├── st-image-bootfs-openstlinux-weston-stm32mp13-disco.ext4                            Binary for bootfs partition on eMMC and microSD card devices
├── st-image-bootfs-openstlinux-weston-stm32mp13-disco.manifest
├── st-image-userfs-openstlinux-weston-stm32mp13-disco.ext4                            Binary for userfs partition on eMMC and microSD card devices
├── st-image-userfs-openstlinux-weston-stm32mp13-disco.manifest
├── st-image-vendorfs-openstlinux-weston-stm32mp13-disco.ext4                          Binary for vendorfs partition on eMMC and microSD card devices
├── st-image-weston-openstlinux-weston-stm32mp13-disco.ext4                            Binary for rootfs partition on eMMC and microSD card devices
├── st-image-weston-openstlinux-weston-stm32mp13-disco.license
├── st-image-weston-openstlinux-weston-stm32mp13-disco-license_content.html            License summary for all packages needed to feed all partitions
└── st-image-weston-openstlinux-weston-stm32mp13-disco.manifest
6.2. Image flashing[edit | edit source]
The STM32CubeProgrammer tool is used to flash the STM32MP135x-DK Discovery kit More info green.png with the downloaded image.
The microSD card, provided in the box, is used as the Flash device: see the STM32MP15 Flash mapping article if you want to know more about the supported Flash memory technologies, and the Flash partitions.
As explained in the boot chain overview, the optee boot chain is the default solution delivered by STMicroelectronics. Thus, the steps below use the image for the optee boot chain.
  • Connect the USB Type-C (OTG) port (7) to the host PC that contains the downloaded image
  • Insert the delivered microSD card into the dedicated slot ('4)
  • Connect the delivered power supply to the USB Type-C port (11)
  • Press the reset button (8) to reset the board
Discovery kit connections for flashing
STM32MP135F-DK shown here (picture is not contractual)
PC $> cd <Starter Package installation directory>/stm32mp13-disco-openstlinux-5.10-dunfell-mp13-21-11-30/images/stm32mp13-disco
If you have followed the the proposition to organize the working directory, the command is
 PC $> cd Starter-Package/stm32mp13-disco-openstlinux-5.10-dunfell-mp13-21-11-30/images/stm32mp13-disco
  • Check that the STM32CubeProgrammer tool is installed and accessible; if not, go to the installation procedure (installing the tools)
PC $> STM32_Programmer_CLI --h
PC $> STM32_Programmer_CLI -l usb
  Device Index           : USB1
  USB Bus Number         : 002
  USB Address Number     : 002
  Serial number          : 000000000000
  Firmware version       : 0x011a
  • Flash the microSD card with the image for the trusted boot chain
PC $> STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-weston/optee/FlashLayout_sdcard_stm32mp135f-dk-optee.tsv
This operation takes several minutes (mainly depending of the rootfs size). A successful flashing outputs the following log:
                        STM32CubeProgrammer v2.9.0
Warning: Timeout is forced to 65535 ms
Product ID  : DFU in HS Mode @Device ID /0x501, @Revision ID /0x1000
SN          : 000080163031510A30333432
FW version  : 0x0110
Board       : --
Device ID   : 0x0501
Device name : STM32MP13xx
Device type : MPU
Revision ID : --
Device CPU  : Cortex-A7
Start Embedded Flashing service
Memory Programming ...
Opening and parsing file: tf-a-stm32mp135f-dk-usb.stm32
  File          : tf-a-stm32mp135f-dk-usb.stm32
  Partition ID  : 0x01
Download in Progress:
File download complete
Time elapsed during download operation: 00:00:00.319
RUNNING Program ...
  PartID:      :0x01
Start operation done successfully at partition 0x01
Opening and parsing file: fip-stm32mp135f-dk-optee.bin
  File          : fip-stm32mp135f-dk-optee.bin
  Partition ID  : 0x03
Time elapsed during download operation: 00:00:01.147
RUNNING Program ...
  PartID:      :0x03
Reconnecting the device ...
Start operation done successfully at partition 0x03
Opening and parsing file: tf-a-stm32mp135f-dk-sdcard.stm32
  File          : tf-a-stm32mp135f-dk-sdcard.stm32
  Partition ID  : 0x04
Time elapsed during download operation: 00:00:00.023
RUNNING Program ...
  PartID:      :0x04
Start operation done successfully at partition 0x04
  Partition ID  : 0x05
Time elapsed during download operation: 00:00:00.022
RUNNING Program ...
  PartID:      :0x05
Start operation done successfully at partition 0x05
  Partition ID  : 0x06
Time elapsed during download operation: 00:00:00.263
RUNNING Program ...
  PartID:      :0x06
Start operation done successfully at partition 0x06
Opening and parsing file: st-image-bootfs-openstlinux-weston-stm32mp13-disco.ext4
  File          : st-image-bootfs-openstlinux-weston-stm32mp13-disco.ext4
  Partition ID  : 0x10
Time elapsed during download operation: 00:00:16.369
RUNNING Program ...
  PartID:      :0x10
Start operation done successfully at partition 0x10
Opening and parsing file: st-image-vendorfs-openstlinux-weston-stm32mp13-disco.ext4
  File          : st-image-vendorfs-openstlinux-weston-stm32mp13-disco.ext4
  Partition ID  : 0x11
Time elapsed during download operation: 00:00:03.981
RUNNING Program ...
  PartID:      :0x11
Start operation done successfully at partition 0x11
Opening and parsing file: st-image-weston-openstlinux-weston-stm32mp13-disco.ext4
  File          : st-image-weston-openstlinux-weston-stm32mp13-disco.ext4
  Partition ID  : 0x12
Time elapsed during download operation: 00:02:28.997
RUNNING Program ...
  PartID:      :0x12
Start operation done successfully at partition 0x12
Opening and parsing file: st-image-userfs-openstlinux-weston-stm32mp13-disco.ext4
  File          : st-image-userfs-openstlinux-weston-stm32mp13-disco.ext4
  Partition ID  : 0x13
Time elapsed during download operation: 00:00:31.960
RUNNING Program ...
  PartID:      :0x13
Start operation done successfully at partition 0x13
Go to the STM32CubeProgrammer article:
  • to know more about the flashing operation
7. Booting the board[edit | edit source]
STM32MP13 Discovery kits - starting for the first time
Subpart - STM32MP13 - Starter Package
8. Examples[edit | edit source]
8.1. Examples running on Cortex-A7[edit | edit source]
9. Fast links to essential commands[edit | edit source]
10. How to go further?[edit | edit source]
Now that the image is flashed on the STM32MP135F-DK Discovery kit, you might want to switch to the STM32MP1 Developer Package, in order to modify or tune the STM32MPU Embedded Software distribution with your own developments.
