This article explains how to configure the MDMA internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the Dmaengine overview.
The configuration is performed using the Device tree mechanism that provides a hardware description of the MDMA internal peripheral, used by the STM32 MDMA Linux driver and by the DMA framework.
Hardware description is a combination of:
- STM32 MDMA peripheral
- and STM32 MDMA client
The STM32MP1 MDMA node is located
For example, at device level, the MDMA is declared as follows:
mdma1: dma@58000000 {
compatible = "st,stm32h7-mdma";
reg = <0x58000000 0x1000>;
interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&rcc MDMA>;
resets = <&scmi0_reset RST_SCMI0_MDMA>;
#dma-cells = <6>;
dma-channels = <32>;
dma-requests = <48>;
The whole configuration remains at STM32 level.
