This article explains how to configure the VDEC [1] when the peripheral is assigned to the Linux® OS.
The configuration is performed using the device tree mechanism [2].
The Device tree provides a hardware description of the VDEC [1] used by the STM32 VDEC Linux driver.
The VDEC is represented by the STM32 VDEC device tree bindings file: st,stm32mp25-video-codec.yaml .
3.1. DT configuration (STM32/SoC level)[edit | edit source]
The VDEC node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
The VDEC device tree node is declared in:
- arch/arm64/boot/dts/st/stm32mp235.dtsi on STM32MP23x lines
&rifsc {
vdec: vdec@480d0000 {
compatible = "st,stm32mp25-vdec";
reg = <0x480d0000 0x3c8>;
resets = <&rcc VDEC_R>;
interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&rcc CK_BUS_VDEC>;
access-controllers = <&rifsc 89>;
power-domains = <&CLUSTER_PD>;
- arch/arm64/boot/dts/st/stm32mp255.dtsi on STM32MP25x lines
&rifsc {
For STM32MP23x lines
and STM32MP25x lines
, the STM32 VDEC is already enabled by default in stm32mp235.dtsi and stm32mp255.dtsi , so there is no need to enable it at board level.
