This article explains how to configure the IWDG internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the IWDG Framework (see watchdog overview).
The configuration is performed using the device tree mechanism that provides a hardware description of the IWDG peripheral.
The IWDG internal peripheral is a watchdog device. Refer to arm-smc-wdt.yaml [1] or to st,stm32-iwdg.yaml [2] for the corresponding binding document.
The STM32MPU IWDG node is located in the SOC dtsi file:
see Device tree for further explanation.
For example, for using SMC driver in U-Boot and Linux:
arm_wdt: watchdog {
compatible = "arm,smc-wdt";
arm,smc-id = <0xb200005a>;
status = "disabled";
For using the native driver:
iwdg2: iwdg@5a002000 {
compatible = "st,stm32mp1-iwdg";
reg = <0x5a002000 0x400>;
clocks = <&rcc IWDG2>, <&rcc CK_LSI>;
clock-names = "pclk", "lsi";
This part is used to enable the IWDG hardware on a board, and define a custom timeout (timeout-sec) in seconds:
&iwdg2 {
timeout-sec = <32>; /* Watchdog timeout value in seconds */
status = "okay";
Only the timeout-sec parameter can be modified, as illustrated above.
