STM32 MPU resources
This article lists all the documents that apply to the STM32 MPU ecosystem release of the STM32MP1 series and STM32MP2 series. Those documents are generally referenced into other wiki pages.
All the resources for the STM32MP1 series resp. STM32MP2 series are located in the STM32MP1 series web page and STM32MP2 series web page.
Reference Name Link
Application notes
AN2834 How to get the best ADC accuracy in STM32 microcontrollers AN2834.pdf
AN4221 I2C protocol used in the STM32 bootloader AN4221.pdf
AN4803 High-speed SI simulations using IBIS and board-level simulations using HyperLynx® SI on STM32 MCUs and MPUs AN4803.pdf
AN5027 Interfacing PDM digital microphones using STM32 MCUs and MPUs AN5027.pdf
AN5036 Thermal management guidelines for STM32 applications AN5036.pdf
AN5054 How to perform secure programming using STM32CubeProgrammer AN5054.pdf
AN5168 How to configure DDR on STM32MP1 MPUs AN5168.pdf
AN5225 USB Type-C® Power Delivery using STM32 MCUs and MPUs AN5225.pdf
AN5275 Introduction to USB DFU/USART protocols used in STM32MP1 and STM32MP2 MPU bootloaders AN5275.pdf
AN5348 Introduction to FDCAN peripherals for STM32 product classes AN5348.pdf
AN5431 The STPMIC1 PCB layout guidelines AN5431.pdf
AN5438 STM32MP1 series lifetime estimates AN5438.pdf
AN5510 Overview of the secure secret provisioning (SSP) on STM32MP1 series AN5510.pdf
AN5827 Guidelines for entering RMA state on STM32MP1 series MPUs AN5827.pdf
AN4879 USB hardware and PCB guidelines using STM32 MCUs AN4879.pdf
AN5474 Getting started with STM32MP13 series hardware development AN5474.pdf
AN5475 Migration of applications from STM32MP15x lines to STM32MP13x lines microprocessor AN5475.pdf
AN5478 Camera-CSI (DCMI-PP) in STM32MP13x microprocessors AN5478.pdf
AN5565 STM32MP13 lines using low-power modes AN5565.pdf
AN5586 STM32MP13x MPU product line discrete power supply hardware integration AN5586.pdf
AN5587 STM32MP13x MPU product lines and STPMIC1D / STPMIC1A integration on a wall adapter supply AN5587.pdf
AN5692 DDR memory routing guidelines for STM32MP13x product lines AN5692.pdf
AN5787 STM32MP13x product lines system power consumption AN5787.pdf
AN6312 How to use STPMIC1L for a wall adapter powered application on STM32MP13x lines MPUs AN6312.pdf
UM1720 STM32Cube USB host library user manual UM1720.pdf
UM1734 STM32Cube USB device library user manual UM1734.pdf
AN5031 Getting started with STM32MP15 Series hardware development AN5031.pdf
AN5109 STM32MP15x lines using low-power modes AN5109.pdf
AN5122 STM32MP1 series DDR memory routing guidelines AN5122.pdf
AN5253 Migration of microcontroller applications from STM32F4x9 lines to STM32MP151, STM32MP153 and STM32MP157 lines microprocessor AN5253.pdf
AN5256 STM32MP151, STM32MP153 and STM32MP157 discrete power supply hardware integration AN5256.pdf
AN5260 STM32MP151/153/157 MPU lines and STPMIC1B integration on a battery powered application AN5260.pdf
AN5284 STM32MP1 series system power consumption AN5284.pdf
AN5723 Guidelines for DDR memory configuration on STM32MP2 MPUs AN5723.pdf
AN5724 Guidelines for DDR memory routing on STM32MP2 MPUs AN5724.pdf
AN5726 STM32MP2 MPUs using low-power modes AN5726.pdf
AN5729 Guidelines for Lifetime Usage Estimates on STM32MP2 MPUs Under preparation
AN5827 Guidelines for entering RMA state on MPU series AN5827.pdf
AN6043 Migrating from STM32MP25x to STM32MP21x MPUs AN6043.pdf
AN6050 Migrating from STM32MP13x to STM32MP21x MPUs AN6050.pdf
AN6055 Getting started with STM32MP21x MPUs hardware development AN6055.pdf
AN6303 How to use STPMIC2L for a wall adapter powered application on STM32MP21x lines AN6303
TN1556 STM32MP21xx Security Target for SESIP level 3 certification Under preparation
AN5718 Migrating from STM32MP15x to STM32MP25x MPUs AN5718.pdf
AN5727 How to use STPMIC25 for a wall adapter powered application on STM32MP25x lines MPUs AN5727.pdf
AN5730 Guidelines for measuring the system power consumption on the STM32MP25x line MPUs AN5730.pdf
AN5489 Getting started with STM32MP23/25xx MPUs hardware development AN5489.pdf
AN6115 STPMIC25 application hints AN6115.pdf
AN6116 STPMIC25 BOM details AN6116.pdf
AN6128 STPMIC25 PCB layout guidelines AN6128.pdf
Datasheets
DS12792 STPMIC1 datasheet
(Power management IC for MPU: 4 buck converters, 1 boost converter and 7 LDOs)
DS12792.pdf
DS14839 STPMIC1L datasheet
(Power management IC for MPU: 2 buck converters and 4 LDOs)
DS14839.pdf
DS14278 STPMIC25 datasheet
(Power management IC for MPU: 7 buck converters and 9 LDOs)
DS14278.pdf
DS14940 STPMIC2L datasheet
(Power management IC for MPU: 3 buck converters and 7 LDOs)
DS14940.pdf
DS13483 STM32MP135C/F Datasheet (STM32MP135C/F)
(secure)
DS13483.pdf
DS13874 STM32MP135A/D Datasheet (STM32MP135A/D)
(non secure)
DS13874.pdf
DS13875 STM32MP133C/F Datasheet (STM32MP133C/F)
(secure)
DS13875.pdf
DS13876 STM32MP133A/D Datasheet (STM32MP133A/D)
(non secure)
DS13876.pdf
DS13877 STM32MP131C/F Datasheet (STM32MP131C/F)
(secure)
DS13877.pdf
DS13878 STM32MP131A/D Datasheet (STM32MP131A/D)
(non secure)
DS13878.pdf
DS12505 STM32MP157C/F datasheet
(secure)
DS12505.pdf
DS12504 STM32MP157A/D datasheet
(basic)
DS12504.pdf
DS12503 STM32MP153C/F datasheet
(secure)
DS12503.pdf
DS12502 STM32MP153A/D datasheet
(basic)
DS12502.pdf
DS12501 STM32MP151C/F datasheet
(secure)
DS12501.pdf
DS12500 STM32MP151A/D datasheet
(basic)
DS12500.pdf
DS14556 STM32MP21xC/F DataSheet DS14556.pdf
DS14557 STM32MP21xA/D DataSheet DS14557.pdf
DS14634 STM32MP23xC/F DataSheet DS14634.pdf
DS14635 STM32MP23xA/D DataSheet DS14635.pdf
DS14284 STM32MP25xC/F Datasheet DS14284.pdf
DS14285 STM32MP25xA/D Datasheet DS14285.pdf
Errata sheets
ES0539 STM32MP13x device errata ES0539.pdf
ES0438 STM32MP15xx device errata ES0438.pdf
ES0628 STM32MP21xA/C/D/F device errata sheet ES0628.pdf
ES0598 STM32MP23xx/25xx device errata ES0598.pdf
Reference manuals
RM0475 STM32MP13x reference manual
(STM32MP135 advanced Arm®-based 32-bit MPUs)
RM0475.pdf
RM0436 STM32MP157 reference manual
(STM32MP157xxx advanced Arm®-based 32-bit MPUs)
RM0436.pdf
RM0442 STM32MP153 reference manual
(STM32MP153xxx advanced Arm®-based 32-bit MPUs)
RM0442.pdf
RM0441 STM32MP151 reference manual
(STM32MP151xxx advanced Arm®-based 32-bit MPUs)
RM0441.pdf
RM0506 STM32MP21x reference manual RM0506.pdf
RM0457 STM32MP23/25 reference manual
(STM32MP23/25xx advanced Arm®-based 32/64-bit MPUs)
RM0457.pdf
Programming manuals
PM0264 STM32 Cortex®-M33 MCUs and MPUs programming manual PM0264.pdf
Boards schematics
MB1635 schematics STM32MP135F-DK motherboard schematics
MB1635-E02 board schematics (Discovery kit)
MB1635-E02.pdf
MB1262 schematics STM32MP157C-EV1 motherboard schematics
MB1262-C01 board schematic (Evaluation board)
MB1262-C01.pdf
MB1263 schematics STM32MP157F-EV1 daughterboard schematics
MB1263-C04 board schematic (Evaluation board)
MB1263-C04.pdf
MB1230 schematics DSI 720p LCD display daughterboard schematics
  • MB1230-C02 board schematic (Evaluation board)
  • MB1230-C01 board schematic (Evaluation board)
MB1230-C01.pdf
MB1230-C02.pdf
MB1379 schematics Camera daughterboard schematics
MB1379-A01 board schematic (Evaluation board)
MB1379-A01.pdf
MB1272 schematics STM32MP157x-DKx motherboard schematics
MB1272-DK2-C02 board schematic (Discovery kit)
MB1272-C02.pdf
MB1272-DK2-C03 board schematic (Discovery kit)
MB1272-C03.pdf
MB1407 schematics STM32MP157x-DKx daughterboard schematics
MB1407-LCD-C01 board schematic (Discovery kit)
MB1407-C01.pdf
MB1407-LCD-C02 board schematic (Discovery kit)
MB1407-C02.pdf
STM32MP215F-DK schematics STM32MP215F-DK schematics mb2059-mp215f-b02-schematic.pdf
B-CAMS-IMX schematics Camera module bundle schematics MB1854-B01.pdf
DDR routing examples schematics Additional DDR memory routing examples examples-of-ddr-memory-routing-on-stm32mpus.zip
STM32MP257F-EV1 schematics STM32MP257F-EV1 board revD schematics with STM32MP25F RevY 18x18 package (MB1936) MB1936-D02.pdf
STM32MP257F-EV1 schematics STM32MP257F-EV1 board revE schematics with STM32MP25F RevY 18x18 package (MB1936) MB1936-E01.pdf
B-LVDS7-WSVGA schematics LVDS TFT LCD module schematics b-lvds7-wsvga.html
STM32MP257F-DK schematics STM32MP257F-DK board schematics example with STM32MP25F RevY 14x14 package STM32MP257F-DK board schematics
DDR routing examples schematics Additional DDR memory routing examples DDR routing examples
Board with STMPIC2L example STM32MP23x lines with STPMIC2LAPQR schematics and layout example Schematics and layout example for board creation with STMPIC2L
Boards user manuals
UM2993 STM32MP135F-DK discovery board user manual UM2993.pdf
UM2534 STM32MP157A-DK1 and STM32MP157C-DK2 Discovery kits user manual UM2534.pdf
UM2535 STM32MP157C-EV1 and STM32MP157A-EV1 Evaluation boards user manual UM2535.pdf
UM2637 STM32MP157D-DK1 and STM32MP157F-DK2 Discovery kits user manual UM2637.pdf
UM2648 STM32MP157F-EV1 and STM32MP157D-EV1 Evaluation boards user manual UM2648.pdf
UM3571 STM32MP215F-DK User Manual UM3571.pdf
UM3359 STM32MP257F-EV1 User Manual UM3359.pdf
UM3385 STM32MP257F-DK User Manual UM3385.pdf
UM3354 B-CAMS-IMX Camera module bundle User Manual UM3354.pdf
Tools user manuals
UM2563 STM32CubeIDE installation guide UM2563.pdf
UM2579 Migration guide from System Workbench to STM32CubeIDE UM2579.pdf
UM2553 STM32CubeIDE quick start guide UM2553.pdf
UM2609 STM32CubeIDE user guide UM2609.pdf
UM1718 STM32CubeMX user manual for STM32CubeMX version up to v6.17.0 UM1718.pdf
STM32CubeMX user manual for STM32CubeMX version from v6.18.0 URL to online documentation
UM2237 STM32CubeProgrammer tool user manual UM2237.pdf
UM2238 STM32 Trusted Package Creator tool user manual UM2238.pdf
UM2542 STM32 series Key Generator tool user manual UM2542.pdf
UM2543 STM32 series Signing tool user manual UM2543.pdf
AN5360 Getting started with projects based on the STM32MP1 series in STM32CubeIDE AN5360.pdf
