STM32MP2 PWR internal peripheral
  • briefly introduce the PWR peripheral and its main features,
The PWR peripheral is used to control the device power supply configuration.
PWR controls, according the the operating mode, and monitors the main supply (VDD, VDDCPU, VDDCORE, ...) and the independent voltage supplies, including the I/O supply (VDDIO) for peripherals eMMC and SD-Card.
It has 6 input pins (named wakeup pins) which can be programmed to wake the system up from low power. The wakeup pins are listed with WKUP prefix in the STM32 MPU Datasheets.
PWR is a RIF-aware peripheral. Each PWR feature could be assigned to the different execution context of the platform following firewall rules described in Resource Isolation Framework overview.
In the case a wakeup pin shall be used by the Cortex®-A35 non secure, it should be assigned to Cortex®-A35 that will forward wake-up event via secure services.
In addition the PWR peripheral drives 3 output hardware lines named PWR_ON, PWR_LP and PWR_CPU_ON according to platform low power mode:
  • with STPMIC (STPMIC25 or STPMIC2L), all 3 lines are used and may control regulators state depending on STPMIC configuration.
  • In the power discrete solution they drive VDDcore which feeds the peripherals. They also control the DDR power supplies (VDD_DDR, VREF_DDR, VTT_DDR) and VDDCpu that feeds the processor.
3.1.1.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Power & Thermal PWR Info.png PWR Shareable at internal peripheral level thanks to the RIF:
see the boot time allocation per feature
The below table shows the possible boot time allocations for the features of the PWR instance on STM32MP2 series for A35-TD flavor More info green.png.
Feature Boot time allocation Info.png Comment
Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Voltage monitoring
RAM & low power
CPU1 power control
CPU2 power control
VDDIO eMMC
VDDIO SD
Wake up 1
Wake up 2
Wake up 3
Wake up 4
Wake up 5
Wake up 6
3.1.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
The below table shows the possible boot time allocations for the features of the PWR instance on STM32MP2 series for M33-TD flavor More info green.png..
Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Voltage monitoring
RAM & low power
CPU1 power control
CPU2 power control
VDDIO eMMC
VDDIO SD
Wake up 1
Wake up 2
Wake up 3
Wake up 4
Wake up 5
Wake up 6
3.2.1. On STM32MP21x lines More info.png[edit | edit source]
3.2.1.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
see the runtime allocation per feature
The below table shows the possible runtime allocations for the features of the PWR instance on STM32MP21x lines More info.png for A35-TD flavor More info green.png.
Feature Runtime allocation Info.png Comment
Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Voltage monitoring OP-TEE
RAM & low power TF-A BL31
CPU1 power control TF-A BL31
CPU2 power control TFA BL31 if TZ_EN if TZ_DIS
VDDIO eMMC OP-TEE
VDDIO SD OP-TEE
Wake up 1 OP-TEE
Wake up 2 OP-TEE
Wake up 3 OP-TEE
Wake up 4 OP-TEE
Wake up 5 OP-TEE
Wake up 6 OP-TEE
3.2.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
The below table shows the possible runtime allocations for the features of the PWR instance on STM32MP21x lines More info.png for M33-TD flavor More info green.png.
Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
CPU1 power control TF-A BL31 Managed by TF-M when CPU1 is in reset
CPU2 power control Managed by TF-A when CPU2 is in reset
VDDIO eMMC OP-TEE
VDDIO SD OP-TEE
Wake up 1 OP-TEE
Wake up 2 OP-TEE
Wake up 3 OP-TEE
Wake up 4 OP-TEE
Wake up 5 OP-TEE
Wake up 6 OP-TEE
3.2.2. On STM32MP23x lines More info.png[edit | edit source]
3.2.2.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
The below table shows the possible runtime allocations for the features of the PWR instance on STM32MP23x lines More info.png for A35-TD flavor More info green.png.
Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
CPU2 power control TF-A BL31 if TZ_EN if TZ_DIS Managed by TF-A when CPU2 is in reset
VDDIO eMMC OP-TEE
VDDIO SD OP-TEE
Wake up 1 OP-TEE
Wake up 2 OP-TEE
Wake up 3 OP-TEE
Wake up 4 OP-TEE
Wake up 5 OP-TEE
Wake up 6 OP-TEE
3.2.2.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
The below table shows the possible runtime allocations for the features of the PWR instance on STM32MP23x lines More info.png for M33-TD flavor More info green.png.
Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
CPU2 power control
VDDIO eMMC OP-TEE
VDDIO SD OP-TEE
Wake up 1 OP-TEE
Wake up 2 OP-TEE
Wake up 3 OP-TEE
Wake up 4 OP-TEE
Wake up 5 OP-TEE
Wake up 6 OP-TEE
3.2.3. On STM32MP25x lines More info.png[edit | edit source]
3.2.3.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
The below table shows the possible runtime allocations for the features of the PWR instance on STM32MP25x lines More info.png for A35-TD flavor More info green.png..
Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
CPU3 power control TF-A BL31
VDDIO eMMC OP-TEE
VDDIO SD OP-TEE
Wake up 1 OP-TEE
Wake up 2 OP-TEE
Wake up 3 OP-TEE
Wake up 4 OP-TEE
Wake up 5 OP-TEE
Wake up 6 OP-TEE
3.2.3.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
The below table shows the possible runtime allocations for the features of the PWR instance on STM32MP25x lines More info.png for M33-TD flavor More info green.png..
Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
CPU2 power control
VDDIO eMMC OP-TEE
VDDIO SD OP-TEE
Wake up 1 OP-TEE
Wake up 2 OP-TEE
Wake up 3 OP-TEE
Wake up 4 OP-TEE
Wake up 5 OP-TEE
Wake up 6 OP-TEE
Below are listed the software frameworks and drivers managing the PWR peripheral for the embedded software components listed in the above tables.
STM32MP2 power overview shows the usage of PWR drivers in OpenSTlinux power management.
