PKA internal peripheral
Applicable for STM32MP13x lines, STM32MP21x lines, STM32MP23x lines, STM32MP25x lines
  • briefly introduce the PKA peripheral and its main features,
The PKA (public key accelerator) peripheral is used to ease computation of cryptographic public key primitives, specifically those related to RSA, Diffie-Hellmann or ECC (elliptic curve cryptography) over GF(p) (Galois fields).
The PKA peripheral is a boot device, it is used for signature verification for binary authentication when device is in secured locked state.
3.1.1. On STM32MP13x lines [edit | edit source]
Domain Peripheral Boot time allocation Comment
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Security PKA PKA Assignment is mandatory only for secure boot
3.1.2.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
3.1.2.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Security PKA PKA
3.2.1. On STM32MP13x lines [edit | edit source]
nonsecure
Security PKA PKA Assignment (single choice)
3.2.2. On STM32MP21x lines [edit | edit source]
The tables below are applicable to any TD flavor (A35-TD or M33-TD) .
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security PKA PKA OP-TEE
3.2.3. On STM32MP23x lines [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.4. On STM32MP25x lines [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Below are listed the software frameworks and drivers managing the PKA peripheral for the embedded software components listed in the above tables.
