The purpose of this article is to explain how to configure the QUADSPI using the device tree mechanism, relying on the bindings documentation, that is the description of the required and optional device-tree properties.
The peripheral can be assigned to different contexts/software components, depending on the final product needs. Refer to How to assign an internal peripheral to an execution context article for guidelines on this configuration.
- TF-A BL2, U-Boot, OP-TEE, Linux® OS:
- Generic SPI-NOR / SPI-NAND Flash memory device tree bindings: Documentation/devicetree/bindings/spi/spi-controller.yaml .
- QUADSPI device tree bindings: Documentation/devicetree/bindings/spi/st,stm32-qspi.yaml .
The QUADSPI node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
The objective of this chapter is to explain how to enable and configure the QUADSPI DT nodes for a board.
Peripheral configuration should be done in specific board device tree files (board dts file and pinctrl dtsi file).
&qspi { Comments
pinctrl-names = "default", "sleep"; --> For pinctrl configuration, please refer to Pinctrl device tree configuration
pinctrl-0 = <&qspi_clk_test_pins_a
&qspi_bk1_test_pins_b
&qspi_cs1_test_pins_b
&qspi_bk2_test_pins_b
&qspi_cs2_test_pins_b>;
pinctrl-1 = <&qspi_clk_test_sleep_pins_a
&qspi_bk1_test_sleep_pins_b
&qspi_cs1_test_sleep_pins_b
&qspi_bk2_test_sleep_pins_b
&qspi_cs2_test_sleep_pins_b>;
reg = <0x58003000 0x1000>,
<0x70000000 0x4000000>; --> Overwrite the memory map to the Flash device size, avoid the waste of virtual memory that will not be used
#address-cells = <1>;
#size-cells = <0>;
status = "okay"; --> Enable the node
flash0: mx66l51235l@0 {
compatible = "jedec,spi-nor";
reg = <0>; --> Chip select number
spi-rx-bus-width = <4>; --> The bus width (number of data wires used)
spi-max-frequency = <108000000>; --> Maximum SPI clocking speed of device in Hz
#size-cells = <1>;
3.3. DT configuration example[edit | edit source]
The below example shows how to configure the QUADSPI peripheral when 1 SPI-NAND Flash and 1 SPI-NOR Flash memories are connected.
&qspi {
#size-cells = <0>;
status = "okay";
reg = <0>;
#size-cells = <1>;
flash1: mt29f2g01abagd@1 {
compatible = "spi-nand";
reg = <1>;
spi-tx-bus-width = <4>;
spi-max-frequency = <133000000>;
#size-cells = <1>;
The below example, possible with ecosystem release ≥ v4.1.0 , shows how to configure the QUADSPI peripheral to use it as a communication channel using up to 8 qspi lines. It can be used to communicate with a FPGA. To enable the usage of the 8 qspi lines, the following properties are mandatory:
- the chip select pins need to be removed from pinctrl-0 and pinctrl-1 properties.
- cs-gpios properties must be populated in the controller node.
- spi-rx-bus-width and spi-tx-bus-width properties must be set to 8 in the device node.
&qspi {
&qspi_bk2_test_pins_b>;
&qspi_bk2_test_sleep_pins_b>;
#size-cells = <0>;
status = "okay";
cs-gpios = <&gpiob 6 GPIO_ACTIVE_LOW>;
fpga@0 {
compatible = "fpga";
reg = <0>;
spi-rx-bus-width = <8>;
spi-tx-bus-width = <8>;
#size-cells = <1>;
