TIM device tree configuration
The purpose of this article is to explain how to configure the TIM internal peripheral using the device tree mechanism, relying on the bindings documentation, that is the description of the required and optional device-tree properties.
When the peripheral is assigned to Linux® OS, it explains:
  • how to enable PWM, trigger or quadrature encoder.
  • how to configure the board, e.g. TIM input/output pins.
It is used by the TIM_OpenSTLinux_drivers that registers relevant information in PWM, IIO and counter frameworks.
The peripheral can be assigned to different contexts/software components, depending on the final product needs. Refer to How to assign an internal peripheral to an execution context for guidelines on this configuration.
The device tree binding documents are stored in the Linux kernel repository:
The TIM internal peripheral[1] is a multifunction device (MFD), providing several functions represented by a separate compatible string:
  • st,stm32-timers deals with core resources. (e.g. registers, clock, DMAs)
  • st,stm32-pwm deals with PWM resources. (e.g. PWM input/output pins)
  • st,stm32-timer-trigger deals with trigger resources (e.g. trigger output connected to other STM32 internal peripherals)
  • st,stm32-timer-counter deals with quadrature encoder resources and external events counter.
DT root node (e.g. timers1...) and DT child nodes describe the TIM features such as:
  • PWM
  • trigger
  • counter and quadrature encoder
They also describe hardware parameters such as registers address, clock and DMA.
TIM nodes are declared in stm32mp131.dtsi[2] on STM32MP13x lines More info.png.
TIM nodes are declared in stm32mp151.dtsi[3] on STM32MP15x lines More info.png.
timers1: timer@address {
	/* timer common resources */
	compatible = "st,stm32-timers";
	pwm {
		/* PWM*/
		compatible = "st,stm32-pwm";
	timer@0 {
		compatible = "st,stm32h7-timer-trigger";
		/* trigger identifier (e.g. 0 for TIM1 triggers, 1 for TIM2... */
		reg = <0>;
	counter {
		compatible = "st,stm32-timer-counter";
3.1.2.1. On STM32MP21x lines More info.png[edit | edit source]
TIM nodes are declared in stm32mp211.dtsi[4] on STM32MP21x lines More info.png.
	compatible = "st,stm32mp21-timers";
	pwm {
		/* PWM*/
		compatible = "st,stm32mp21-pwm";
	timer@0 {
		compatible = "st,stm32mp21-timer-trigger";
		reg = <0>;
	counter {
		compatible = "st,stm32mp21-timer-counter";
3.1.2.2. On STM32MP23x lines More info.png and STM32MP25x lines More info.png[edit | edit source]
TIM nodes are declared in stm32mp231.dtsi[5] on STM32MP23x lines More info.png.
TIM nodes are declared in stm32mp251.dtsi[6] on STM32MP25x lines More info.png.
	compatible = "st,stm32mp25-timers";
	pwm {
		/* PWM*/
		compatible = "st,stm32mp25-pwm";
	timer@0 {
		compatible = "st,stm32mp25-timer-trigger";
		reg = <0>;
	counter {
		compatible = "st,stm32mp25-timer-counter";
The objective of this chapter is to explain how to enable and configure the TIM DT nodes for a board:
  • Enable DT root node for the TIM instances in use (e.g timers1...) by setting status = "okay";
  • Enable DT child node(s) for the feature(s) in use (PWM input/output, trigger and quadrature encoder) by setting status = "okay";
  • Configure pins in use via pinctrl through pinctrl-0, pinctrl-1 and pinctrl-names.
To enable PWM capture on the board (optional), DMA must be configured:
  • Enable DMA channel(s) corresponding to the PWM input(s) by setting dmas = <...>, <...>; and matching dma-names = "ch1", "ch3";.
When PWM capture isn't used, it's recommended to disable DMA channels by default, to spare them for other usage:
  • Disable DMA channels by setting /delete-property/dmas and /delete-property/dma-names
Peripheral configuration should be done in specific board device tree files (board dts file and pinctrl dtsi file).
3.3.1. TIM configured in PWM mode[edit | edit source]
The example below shows how to configure TIM1 channel 1 to act as:
/* select TIM1_CH1 alternate function 1 on 'PE9' */
pwm1_pins_a: pwm1-0 {
	pins {
		pinmux = <STM32_PINMUX('E', 9, AF1)>;
		bias-pull-down;
		drive-push-pull;
		slew-rate = <0>;
/* configure 'PE9' as analog input in low-power mode */
pwm1_sleep_pins_a: pwm1-sleep-0 {
	pins {
		pinmux = <STM32_PINMUX('E', 9, ANALOG)>;
The PWM output doesn't require any DMA channel. Disable them if they are configured by default in the .dtsi file.
/* PWM DT provider on TIM1: "pwm1" */
&timers1 {
	status = "okay";
	/* spare all DMA channels since they are not needed for PWM output */
	/delete-property/dmas;
	/delete-property/dma-names;
	/* define pwm1 label */
	pwm1: pwm {
		/* configure PWM pins on TIM1_CH1 */
		pinctrl-0 = <&pwm1_pins_a>;
		pinctrl-1 = <&pwm1_sleep_pins_a>;
		/* enable PWM on TIM1 */
		status = "okay";
  • PWM DT user example
The TIM PWM DT user specifier encodes 3 cells:
  • PWM number (0 for CH1, 1 for CH2 and so on)
  • PWM period in nanoseconds
  • PWM polarity (0 for normal polarity or PWM_POLARITY_INVERTED)
	/* PWM DT user on TIM1_CH1: "pwm1", example with "pwm-leds"[7] */
	pwmleds {
		compatible = "pwm-leds";
		example {
			label = "stm32-pwm-leds-example";
			/* Use pwm1 channel 0 (e.g. TIM1_CH1) */
			/* period in nanoseconds (500000), normal polarity (0) */
			pwms = <&pwm1 0 500000 0>;
			max-brightness = <127>;
3.3.2. TIM configured in PWM mode and trigger source[edit | edit source]
	pins {
		bias-pull-down;
		drive-push-pull;
		slew-rate = <0>;
	pins {
&timers1 {
	status = "okay";
	pwm {
		/* configure PWM on TIM1_CH1 */
		status = "okay";
	timer@0 {
		/* enable trigger on TIM1 */
		status = "okay";
3.3.3. TIM configured in counter capture mode[edit | edit source]
The example below shows how to configure TIM10 channel 1 in counter capture mode, based on the counter subsystem.
It is available on available on STM32MP257x-EV1 GPIO expansion connector.
/* select TIM10_CH1 alternate function 9 on 'PB9' */
	tim10_counter_pins_a: tim10-counter-0 {
		pins {
			pinmux = <STM32_PINMUX('B', 9, AF9)>; /* TIM10_CH1 */
			bias-disable;
/* configure 'PB9' as analog input in low-power mode */
	tim10_counter_sleep_pins_a: tim10-counter-sleep-0 {
		pins {
			pinmux = <STM32_PINMUX('B', 9, ANALOG)>; /* TIM10_CH1 */
Note: one or more channels may be configured for capture.
  • Configure and enable the timer 10 to act as counter device:
/* Enable timer 10 multi-function device. */
&timers10 {
	status = "okay";
	/* Enable timer 10 counter device. */
	counter {
		pinctrl-0 = <&tim10_counter_pins_a>;
		pinctrl-1 = <&tim10_counter_sleep_pins_a>;
		status = "okay";
3.3.4. TIM configured in PWM input capture mode[edit | edit source]
This chapter is only applicable for STM32MP1 series.
It is recommended to use the TIM configured in counter capture mode instead of PWM input capture mode.
This example shows how to configure TIM1 channel 1 in PWM input capture mode (e.g. period and duty cycle).
pwm1_in_pins_a: pwm1-in-0 {
	pins {
		bias-disable;
pwm1_in_sleep_pins_a: pwm1-in-sleep-0 {
	pins {
A DMA channel is required and must be configured depending on the PWM input channel:
  • Select DMA channel 1, "ch1", to capture PWM input channel 1 and/or 2
  • Select DMA channel 3, "ch3", to capture PWM input channel 3 and/or 4
  • Select both "ch1" and "ch3" dmas to enable capture on all PWM input channels
&timers1 {
	status = "okay";
	/* Enable DMA "ch1" for PWM input on TIM1_CH1 */
	dmas = <&dmamux1 11 0x400 0x1>;
	dma-names = "ch1";
	pwm {
		/* configure PWM input pins, e.g. TIM1_CH1 */
		pinctrl-0 = <&pwm1_in_pins_a>;
		pinctrl-1 = <&pwm1_in_sleep_pins_a>;
		status = "okay";
DMA channels 1 and/or 3 for each TIM can be picked from the "dmas" list in stm32mp131.dtsi[2] or stm32mp151.dtsi[3] files
3.3.5. TIM configured as quadrature encoder interface[edit | edit source]
The example below shows how to configure TIM1 to interface with a quadrature encoder, based on the counter subsystem:
On the STM32MP157X-DKX discovery board, TIM1_CH1 and TIM1_CH2 signals are accessible via the D6 and D10 pins of the Arduino Uno connector.
tim1_in_pins_a: tim1-in-pins-0 {
	pins {
		pinmux = <STM32_PINMUX('E', 9, AF1)>, /* TIM1_CH1 */
			 <STM32_PINMUX('E', 11, AF1)>; /* TIM1_CH2 */
		bias-disable;
tim1_in_pins_sleep_a: tim1-in-pins-sleep-0 {
	pins {
		pinmux = <STM32_PINMUX('E', 9, ANALOG)>, /* TIM1_CH1 */
			 <STM32_PINMUX('E', 11, ANALOG)>; /* TIM1_CH2 */
&timers1 {
	status = "okay";
	/delete-property/dmas;                       /* spare all DMA channels since they are not required for quadrature encoder interface */
	counter {
		pinctrl-0 = <&tim1_in_pins_a>;       /* configure TIM1_CH1 and TIM1_CH2 as encoder input pins */
		pinctrl-1 = <&tim1_in_pins_sleep_a>;
		status = "okay";                     /* enable Encoder interface mode on TIM1 */
