LPUART internal peripheral
  • briefly introduce the LPUART peripheral and its main features,
The LPUART peripheral is similar to the UART, with minimum power consumption.
High-speed data communications can be achieved by using the HPDMA or LPDMA for multibuffer configuration.
3.1.1.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Low speed interface LPUART LPUART1
3.1.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
3.2.1. On STM32MP21x lines More info.png and STM32MP23x lines More info.png[edit | edit source]
The present chapter describes STMicroelectronics recommendations or choice of implementation. Additional possibilities might be described in STM32MP21 reference manuals and in STM32MP23 reference manuals.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Low speed interface LPUART LPUART1 OP-TEE
TF-A BL31
3.2.2. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
TF-A BL31
The STM32MP2 series devices feature a LPUART instance supporting only Asynchronous mode.
Below are listed the software frameworks and drivers managing the LPUART peripheral for the embedded software components listed in the above tables.
See also additional information in the Serial TTY device tree configuration article for Linux®.
