This article explains how to configure the USBPHYC internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the PHY framework.
The configuration is performed using the device tree mechanism.
It is used by the USBPHYC Linux driver[1] which registers the relevant information in PHY framework.
USBPHYC device tree bindings[2] describe all the required and optional functions.
USBPHYC
|_ PLL
|_ PHY port#1 _________________ HOST controller
| _ |
| / 1|________________|
|_ PHY port#2 ----| |________________
| \_0| |
|_ UTMI switch_______| OTG controller
The USBPHYC node is declared in:
It is composed of several nodes:
- root node e.g. usbphyc describes the USBPHYC hardware block parameters such as registers, clocks, resets and supplies.
- child nodes e.g. usbphyc_port0 and usbphyc_port1 describe the two high speed PHY ports: port#1 and port#2.
usbphyc: usbphyc@address {
compatible = "st,stm32mp1-usbphyc";
... /* usbphyc resources: registers, clocks, resets and supplies */
usbphyc_port0: usb-phy@0 {
... /* usbphyc HS PHY port#1 */
usbphyc_port1: usb-phy@1 {
... /* usbphyc HS PHY port#2 */
Follow the sequences described in the below chapters to configure and enable the USBPHYC on your board.
The 'usbphyc' root node must be filled in:
- Enable the USBPHYC block by setting status = "okay".
The child nodes for each port must be filled in:
- Configure the USBPHYC 3V3 regulator[5] by setting phy-supply = <&your_regulator>.
| USB HS PHY ports require an external 3V3 power supply to be provided at VDD3V3_USBHS pin. |
- Optional, you may configure the VBUS 5V regulator[5] by using a connector node with vbus-supply = <&your_regulator>. Have a look at connector bindings [6]
- Optional, each PHY port parameters may be tuned by adding properties directly inside the child node of each port.
| It may be necessary to adjust the phy settings to compensate parasitics, which can be due to USB connector/receptacle, routing, ESD protection component.
Optional tuning parameter list is available in USBPHYC device tree bindings[2]. |
3.3. DT configuration example[edit | edit source]
The example below shows how to enable and configure USBPHYC ports in the board file.
&usbphyc {
status = "okay"; /* enable USB HS PHY controller */
&usbphyc_port0 {
phy-supply = <&vdd_usb>; /* references the 3V3 voltage regulator on the user board */
st,tune-hs-dc-level = <2>; /* optional USB HS PHY port#1 tuning */
st,enable-fs-rftime-tuning;
st,enable-hs-rftime-reduction;
st,trim-hs-current = <15>;
st,trim-hs-impedance = <1>;
st,tune-squelch-level = <3>;
st,tune-hs-rx-offset = <2>;
st,no-lsfs-sc;
connector {
compatible = "usb-a-connector";
vbus-supply = <&vbus_sw>; /* references the optional 5V voltage regulator on the user board */
&usbphyc_port1 {
st,tune-hs-dc-level = <2>; /* optional USB HS PHY port#2 tuning */
st,no-lsfs-sc;
Static configuration of the UTMI switch to assign the port#2 to either USBH or OTG is done by the PHY user node[7]:
usbphyc_port1 user must configure an additional specifier for UTMI switch: 0 to select OTG, 1 to select USBH |
Abstract of the example to configure port#2, to be assigned to the USBH:
&usbh_ehci {
phys = <&usbphyc_port0>, <&usbphyc_port1 1>; /* 1: UTMI switch selects the USBH */
phy-names = "usb", "usb";
Abstract of the example to configure port#2, to be assigned to the OTG:
&usbotg_hs {
phys = <&usbphyc_port1 0>; /* 0: UTMI switch selects the OTG */
phy-names = "usb2-phy";
- ↑ drivers/phy/st/phy-stm32-usbphyc.c , STM32 USB PHY Controller driver
- ↑ 2.0 2.1 Documentation/devicetree/bindings/phy/phy-stm32-usbphyc.yaml , USBPHYC device tree bindings
- ↑ arch/arm/boot/dts/st/stm32mp131.dtsi , STM32MP131 device tree file
- ↑ arch/arm/boot/dts/st/stm32mp151.dtsi , STM32MP151 device tree file
- ↑ 5.0 5.1 Regulator overview
- ↑ Documentation/devicetree/bindings/connector/usb-connector.yaml
- ↑ Documentation/devicetree/bindings/phy/phy-bindings.txt ,PHY generic bindings
