STM32MP15 RAM mapping
This article describes how the STM32 MPU Embedded Software distribution maps the various software memory needs in internal and external volatile memories.
2. Arm core characteristics[edit | edit source]
2.1. Reset address[edit | edit source]
2.2. Cortex-M4 multiple ports[edit | edit source]
  • I-bus is used to fetch code instructions in the 0x00000000--0x1FFFFFFF address range
  • D-bus is used to read/write data in the 0x00000000--0x1FFFFFFF address range
  • S-bus is used for all accesses in the 0x20000000--0xFFFFFFFF address range; all STM32MP15 internal peripherals registers are mapped in this range.
3. Memory mapping[edit | edit source]
3.1. Overall memory mapping[edit | edit source]
DDRBackup registersBKPSRAMCAN SRAMRETRAMRETRAMSYSRAMMCU SRAMMCU SRAMROM
STM32MP15 memory mapping
3.2. Zoom in the Cortex-A7/Cortex-M4 shared memory[edit | edit source]
The figure below is a zoom of the RAM areas that are shared between the Cortex-A7 nonsecure and the Cortex-M4. This mapping is STMicroelectronics' default implementation that can be freely adapted by customers to fit to other needs.
3.3. Possible customization of shared RAM memory[edit | edit source]
As described in STM32MP15 MCU SRAM internal memory, ST has defined a memory mapping to be able to enable all the possible use cases in parallel but this can be customized depending on customer use cases.
3.3.1. Overview[edit | edit source]
  • RETRAM is not used except for the vector table which must be stored at address 0. The rest of this memory section can be used for any purpose.
  • MCU SRAM1 (Code) and SRAM2 (Data) sizes can be tuned depending on user needs to better use physical area of 256KB.
  • MCU SRAM3 (IPC Buffers) can be used for other purpose if IPC is not used
  • MCU SRAM4 (DMA) can be used for other purpose if DMA1 and/or DMA2 is not used in chained mode (using MDMA)
3.3.2. How to do that in practice[edit | edit source]
  • on Cortex-A7: in Linux device tree, using Reserved_memory mechanism
  • on Cortex-M4: in the linker script
3.3.2.1. RETRAM[edit | edit source]
  • Linux Device tree
"retram" memory region declaration (no update needed):
retram: retram@0x38000000 {
	reg = <0x38000000 0x10000>;
	no-map;
No update needed for m4_proc node.
&m4_rproc {
	ranges =  <0x00000000 0x38000000 0x10000>,
			 <0x30000000 0x30000000 0x60000>,
			 <0x10000000 0x10000000 0x60000>;
  • Cortex-M4 STM32Cube firmware
In STM32Cube linker script definition (.ld): keep vector table "m_interrupts" but any new section can be added on top to use RETRAM free memory space:
MEMORY
    m_any_section .... : ..................
3.3.2.2. MCU SRAM4[edit | edit source]
  • Linux device tree
Remove followings declarations:
&sram {
    dma_pool: dma_pool@0 {
    reg = <0x50000 0x10000>;
    pool;
&dma1 {
	sram = <&dma_pool>;
&dma2 {
	sram = <&dma_pool>;
3.3.2.3. MCU SRAM3[edit | edit source]
  • Linux device tree
Remove followings memory region declarations:
		vdev0vring0: vdev0vring0@10040000 {
			reg = <0x10040000 0x1000>;
			no-map;
		vdev0vring1: vdev0vring1@10041000 {
			reg = <0x10041000 0x1000>;
			no-map;
		vdev0buffer: vdev0buffer@10042000 {
			reg = <0x10042000 0x4000>;
			no-map;
Remove associated reference in m4_rproc node:
&m4_rproc {
  • Cortex-M4 STM32Cube firmware:
Must be aligned with STM32Cube linker script definition (.ld), remove "m_ipc_shm":
MEMORY
3.3.2.4. MCU SRAM1 & SRAM2[edit | edit source]
  • Linux device tree
Only one section is declared for STM32Cube firmware code and data in Linux device tree
Notice that the MCURAM is aliased so accessible at addresses 0x10000000 or 0x30000000. In consequence mcuram and mcuram2 memory sections definitions have to be coherent.
	mcuram: mcuram@ 0x30000000 {
		reg =  <0x30000000 0x40000>; /* define memory base and size for Cortex-M4 firmware*/
		no-map;
	mcuram2: mcuram2@0x10000000 {
		reg = <0x10000000 0x40000>; /* define memory base and size for Cortex-M4 firmware*/
		no-map;
&m4_rproc {
The memory mapping you have defined on Linux side (freed for M4 usage) needs to be consistent with STM32Cube linker script definition (.ld):
MEMORY
