SPDIFRX device tree configuration
This article explains how to configure the SPDIFRX internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the ALSA framework.
The configuration is performed using the device tree mechanism that provides a hardware description of the SPDIFRX peripheral, used by the SPDFIRX linux driver.
STM32 SPDIFRX device tree bindings [1] document describes all the required and optional configuration properties.
This hardware description is a combination of STM32 microprocessor [2] and board device tree files. See the Device tree for an explanation of the device tree file split.
The SPDIFRX node is declared in STM32 microprocessor device tree. It describes hardware parameters such as registers address, interrupt and DMA. This set of properties may not vary for a given STM32MPU.
On STM32MP13x lines More info.png, the SPDIFRX nodes are declared in stm32mp131.dtsi[3].
On STM32MP15x lines More info.png, the SPDIFRX nodes are declared in stm32mp151.dtsi[4].
On STM32MP21x lines More info.png, the SPDIFRX nodes are declared in stm32mp211.dtsi[5].
On STM32MP23x lines More info.png, the SPDIFRX nodes are declared in stm32mp231.dtsi[6].
On STM32MP25x lines More info.png, the SPDIFRX nodes are declared in stm32mp251.dtsi[7].
The SPDIFRX is an audio peripheral, which can be used as a component of a soundcard through Linux® kernel ALSA framework. This part of the device tree allows the configuration of the SPDIFRX to implement a soundcard. Refer to soundcard configuration for examples of SPDIFRX configuration on various boards.
&spdifrx {
	pinctrl-0 = <&spdifrx_pins_a>;
	pinctrl-1 = <&spdifrx_sleep_pins_a>
	/* Use spdifrx_pins_a instead of spdifrx_sleep_pins_a configuration,
	to allow IEC958 status bits capture, when an audio stream record is
	not active. Note that sleep state has to be defined, to allow pin state
	recovery from low power modes. */
	spdifrx_port: port {
		spdifrx_endpoint: endpoint {
			remote-endpoint = <&spdif_in_endpoint>;
