LPTIM internal peripheral
  • briefly introduce the LPTIM peripheral and its main features,
The LPTIM peripheral is a single channel low-power timer unit, that can continue to run even during low power modes when it selects a clock source that remains active in RCC.
The LPTIM peripheral is available in different configurations. Depending on the selected instance, it can act as PWM, quadrature encoder[1], external event counter or trigger source for other internal peripherals, like ADC, DAC and DFSDM (on STM32MP1 series) or MDF (on STM32MP2 series).
  • LPTIM on STM32MP1 series
LPTIM instances Independent Channels PWM External event counter
Trigger source
Quadrature encoder
LPTIM1, LPTIM2 1 Yes Yes Yes
LPTIM3 1 Yes Yes
LPTIM4, LPTIM5 1 Yes
  • LPTIM on STM32MP2 series
Trigger source
Quadrature encoder
LPTIM1, LPTIM2 2 Yes Yes Yes
LPTIM3, LPTIM4 2 Yes Yes
LPTIM5 1 Yes Yes
3.1.1. On STM32MP13x lines More info.png[edit | edit source]
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Core/Timers LPTIM LPTIM1
LPTIM2
LPTIM3
LPTIM4
LPTIM5
3.1.2. On STM32MP15x lines More info.png[edit | edit source]
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Core/Timers LPTIM LPTIMx (x = 1 to 5) LPTIM are not used at boot time.
3.1.3. On STM32MP2 series[edit | edit source]
3.1.3.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
3.1.3.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
nonsecure
LPTIM2 Assignment (single choice)
LPTIM3 Assignment (single choice)
LPTIM3 can be used for HSE monitoring.
LPTIM4
LPTIM5
nonsecure
Cortex-M4
Core/Timers LPTIM LPTIMx (x = 1 to 5) Assignment (single choice)
3.2.3. On STM32MP21x lines More info.png and STM32MP23x lines More info.png[edit | edit source]
The present chapter describes STMicroelectronics recommendations or choice of implementation. Additional possibilities might be described in STM32MP21 reference manuals and in STM32MP23 reference manuals.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core/Timers LPTIM LPTIM1 OP-TEE LPTIM1 can be used for HSE monitoring.
LPTIM2 OP-TEE
LPTIM3 OP-TEE LPTIMy (y = 3, 4, 5) can be used for scheduling in low power modes by Linux
LPTIM4 OP-TEE LPTIMy (y = 3, 4, 5) can be used for scheduling in low power modes by Linux
LPTIM5 OP-TEE LPTIMy (y = 3, 4, 5) can be used for scheduling in low power modes by Linux
3.2.4. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
LPTIM2 OP-TEE
Below are listed the software frameworks and drivers managing the LPTIM peripheral for the embedded software components listed in the above tables.
For Linux kernel configuration, please refer to LPTIM device tree configuration and STM32 LPTIM Linux driver articles.
