STM32MP257x-EV1 - hardware description
STM32MP257F-EV1.jpg This article provides an overview of STM32MP257x-EV1 Evaluation boards.
  • How to assemble the different elements provided in the commercial box
  • The different components on the boards
  • How to connect the boards to external material
  • How to configure the board for boot
  • The configurations of the connector pins
This article is valid for the STM32MP257F-EV1 More info green.png Evaluation boards: the part numbers are specified in the STM32MP25 microprocessor part numbers article.
This article is an introduction to the STM32MP257x-EV1 Evaluation board. For more detailed information, refer to the STM32MP257x-EV1 Evaluation boards user manuals.
2. Board assembly[edit | edit source]
The STM32MP257x-EV1 Evaluation board packages (STM32MP257F-EV1 More info green.png), completed by the B-CAMS-IMX package, include the items listed below.
STM32MP257F-EV1 shown here (picture is not contractual)
Position Description
1 MB1936 main board
2 7” LVDS WSVGA display with touch panel (EDT ETML0700Z9NDHA panel) (optional)
3 LVDS display cable (optional)
4 MB1854 board AI camera (not part of the STM32MP257x-EV1 Evaluation board package; provided with the B-CAMS-IMX package) (optional)
5 Camera board FFC (not part of the STM32MP257x-EV1 Evaluation board package; provided with the B-CAMS-IMX package) (optional)
LVDS displays and CSI cameras are available for purchase to complete this basic setup.
The complete set looks like this:
STM32MP257x-EV1 Evaluation board assembly
2.1. Connecting the LVDS display to the board[edit | edit source]
Display board assembly (picture is not contractual)
  • Check the cable orientation shown above using the black mark and the white twisted pairs.
  • Find the LVDS ports on the STM32MP257x-DK Discovery kit (CN2) and the display (CN1). The LVDS display box contains one cable.
  • Insert the cable into each port as shown below:
2.2. Connecting the MB1854 camera board to the board[edit | edit source]
Camera board assembly (picture is not contractual)
  • Find the camera ports on the STM32MP257x-EV1 Evaluation board (CN4) and MB1854 (CN1). One FFC is provided in the camera box.
  • For each port:
    • Pull the black plastic (#1 in the image below) lightly to insert the contact side of the FFC towards the board (#2 in the image below).
    • Push the black plastic carefully to hold the FFC (#3 in the image below).
2.3. STM32MP257x-EV1 Evaluation board assembled[edit | edit source]
3. Board overview[edit | edit source]
Main board MB1936, revision D-01: part of the STM32MP257x-EV1 Evaluation board More info green.png.
It is highly recommended to work with a main board MB1936, revision D-01 instead of a main board MB1936, revision C-01, because the latter presents the following restrictions:
  • Low-power modes are not functional.
  • DSI HDMI is not functional (one line (DISP.DSI_INT = PD10) for CEC is not present in Rev. C, while it is available on Rev. D).
Position Description Position Description
1 (LED1) User LED (blue) [* 1] 2 (LD1) User LED (red) [* 1]
3 (LD2) User LED (orange) [* 1] 4 (LD3) User LED (green) [* 1]
5 (B1) RESET button 6 (B2) WAKE UP button
7(B3) TAMPER button 8 (B4) USER2 button
9 (B5) USER1 button 10 (CN2) LVDS connector
11(CN4) CSI connector 12(CN3) DSI connector
13 (CN1) microSD card connector 14 (SW1) Boot mode selection
15 (U22) S-NOR 512Mb 16 (CN5) GPIO expansion connector
17 (CN9) FDCAN1 18 (CN11) FDCAN2
19 (U26) STPMIC25 20 (U27) STM32MP257
21 (U24) eMMC 4GB 22 (U29) DDR4 2GB
23(U28) DDR4 2GB 24 (CN10) PWR measurements connector
25 (CN22) MIPI10 connector 26 (CN13) Mini-PCIe connector
27 (JP4) Power jumper 28 (CN20) 5V/3A power supply jack
29 (CN21) USB Power - ST-LINK Type-C 30 (CN16) ETHERNET 2 / PHY ETH2
31 (CN17) ETHERNET 1 / PHY ETH1 32 (CN18) ETHERNET 3 / PHY ETH3
33 (CN19) Dual USB Host TypeA 34 (CN15) USB2.0 DRD Type-C
35 (LD7) Ethernet LED (green)[* 2] 36 (LD8) Ethernet LED (green)[* 2]
37 (LD9) Ethernet LED (green)[* 2] 38 (LD11) Power LED (green)[* 3]
39 (LD5) ST-LINK/V3-1 LED (bicolor)[* 4] - -
Details about the LEDs:
  1. 1.0 1.1 1.2 1.3 LD2, LD3, LD4, LD5 (MB1936): some user LEDs are used to reflect the system activity, while others are left free for use by the application, as explained in the LEDs and buttons on STM32 MPU boards article.
  2. 2.0 2.1 2.2 LD7, LD8, LD9 (MB1936): these LEDs blink in green when an Ethernet connection has been established
  3. LD11 (MB1936): turns green when a power connection has been established.
  4. LD6 (MB1263): blinks in red if the ST-LINK/V3-1 connection was not established, otherwise it is green.
STM32MP257x-EV1 Evaluation board front side
STM32MP257x-EV1 Evaluation board back side
STM32MP257A-EV1 shown here (picture is not contractual)
40 (CN25) mikroBUS connector
4. Board connection[edit | edit source]
The images below shows the recommended connections for getting started with the STM32MP257x-EV1 Evaluation boards. As shown in the board overview, other connectors are available for this board (for example, CAN).
USB Power Delivery Type-C (Power or  STLINK)ETHERNET 2/PHY ETH2 (Ethernet)2 x USB type A (host) (such as a mouse or keyboard USB driver)USB2.0 DRD Type-C  (programmable through CubeProgrammer)microSD<sup>™</sup> card slotMB1936 5V/3A power supply jack (Power)RESET button
STM32MP257x-EV1 Evaluation board connections
5. Switches and jumpers[edit | edit source]
Most of the default settings for the switches and jumpers must be kept as they are in the commercial box.
There are two exceptions:
  • The jumpers related to power
  • The switches related to boot
The sections below provide further details for the main boot switches and power jumpers.
5.1. Power jumper[edit | edit source]
Depending on the positions presented in the table below, the power jumper (JP4) provides the the MB1936 board with either:
  • A 5V/3A power supply unit (not provided with the STM32MP25 Evaluation board package) on the jack CN20
  • A USB PD Type-C CN21 (USB cable not provided with the STM32MP25 Evaluation board package)
Jumper Setting Configuration
JP4 JP[1-2] Select the USB Power Delivery Type-C CN21 as the main board supply (USB Type-C cable)
JP4[2-3] Select the 5V/3A power supply unit on jack CN20 as the main board supply
MB1936 board supplied via USB Power Type-C CN21 (picture is not contractual)
MB1936 board supplied via 5V/3A power supply unit CN20 (picture is not contractual)
5.2. Boot-related switches[edit | edit source]
The STM32MP257x-EV1 Evaluation boards can boot from different flash memory devices (such as microSD, eMMC, or serial NOR) based on ROM code selection; using the microSD card is recommended.
Flavor Boot 0 Boot 1 Boot 2 Boot 3 Boot-related switches for (SW1 on the board overview picture) Storage device used for the Cortex-A35 boot Storage device used for the Cortex-M33 boot
For any TD flavor (A35-TD or M33-TD) More info green.png 0 0 0 0
Boot from UART/USB
UART/USB
for programming
NA
1 1 0 0
Development mode
Development boot NA
A35-TD flavor More info green.png 1 0 0 0
Boot from microSD card
microSD NA
0 1 0 0
Boot from eMMC
eMMC NA
0 0 1 0
Boot from serial NOR
serial NOR NA
M33-TD flavor More info green.png 1 1 0 1 serial NOR serial NOR
1 1 1 0
microSD card microSD card
0 0 0 1 eMMC eMMC
1 0 1 1 eMMC serial NOR
0 1 1 1 microSD card serial NOR
When the switch is set to the "OPEN" position, the BOOTx value is "0"; otherwise it is "1".
6. GPIO mapping[edit | edit source]
6.1. GPIO expansion connector[edit | edit source]
The table below describes the pins of the GPIO expansion connector (CN5 in the board overview image):
3V3 - 1 2 - 5V
GPIO2 / I2C8_SDA PZ3 3 4 - 5V
GPIO3 / I2C8_SDL PZ4 5 6 - GND
GPIO4 / MCO1 PF11 7 8 PF13 GPIO14 / USART6_TX
GND - 9 10 PF14 GPIO15 / USART6_RX
GPIO17 / USART6_RTS PG5 11 12 PJ11 GPIO18 / SAI2_SCKA
GPIO27 / SDMMC3_D3 PI11 13 14 - GND
GPIO22 / SDMMC3_CK PB13 15 16 PD12 GPIO23 / SDMMC3_CMD
3V3 - 17 18 PB14 GPIO24 / SDMMC3_D0
GPIO10 / SPI3_MOSI PB8 19 20 - GND
GPIO9 / SPI3_MISO PB10 21 22 PD13 GPIO25 / SDMMC3_D1
GPIO11 / SPI3_SCK PB7 23 24 PB1 GPIO8 / SPI3_NSS
GND - 25 26 PJ1 GPIO7
ID_SD/I2C2_SDA PB4 27 28 PB5 ID_IC/I2C2_SCL
GPIO5 / TIM8_CH4 PJ4 29 30 - GND
GPIO6 / TIM12_CH2 PB11 31 32 PB9 GPIO12 / TIM10_CH1
GPIO13 / TIM8_CH1 PJ5 33 34 - GND
GPIO19 / SAI2_FSA PJ3 35 36 PF15 GPIO16 / USART6.CTS
GPIO26 / SDMMC3_D2 PB12 37 38 PJ12 GPIO20 / SAI2_SDA
GND - 39 40 PJ2 GPIO21 / SAI2_SDB
6.2. User buttons and LEDs[edit | edit source]
The tables below describe the GPIO assignments for the user buttons and LEDs. Refer to the LEDs and buttons on STM32 MPU boards article for more details.
GPIO for LEDs
LED color and label GPIO
Orange LED (LD3) PJ6
Red LDE (LD1) PH4
Green LED (LD2) PD8
Blue LED (LD4) PJ7
GPIO for user buttons
Button GPIO
USER1 (B5) PD2
USER2 (B4) PA13
