SYSCFG internal peripheral
  • briefly introduce the SYSCFG peripheral and its main features,
The SYSCFG peripheral is used to configure various system aspects like IOs compensation, Ethernet clocking path, …
The SYSCFG peripheral is configured by TF-A and U-Boot at boot time.
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Core SYSCFG SYSCFG
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Core SYSCFG SYSCFG
nonsecure
Core SYSCFG SYSCFG
nonsecure
Cortex-M4
Core SYSCFG SYSCFG
3.2.3. On STM32MP21x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core SYSCFG SYSCFG
3.2.4. On STM32MP23x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core SYSCFG SYSCFG
3.2.5. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Core SYSCFG SYSCFG
Below are listed the software frameworks and drivers managing the SYSCFG peripheral for the embedded software components listed in the above tables.
Linux and STM32CubeMP15 Package or STM32MP2 Package can directly change the SYSCFG at runtime from various drivers.
  • Linux®: for example, Linux I2C driver uses the syscon framework[1] to enable the I2C fast mode plus (FM+) in the SYSCFG for the instances allocated to itself
  • STM32Cube: for example, I2C HAL driver uses its SYSCFG HAL driver to do the same on the instances allocated to itself
