SAES internal peripheral
Applicable for STM32MP13x lines, STM32MP21x lines, STM32MP23x lines, STM32MP25x lines
  • briefly introduce the SAES peripheral and its main features,
The SAES peripheral provides hardware acceleration to encrypt or decrypt data using the AES[1] algorithms. It supports two key sizes (128 bits and 256 bits) and different chaining modes. It incorporates protections against differential power analysis (DPA) and the related side-channel attacks.
The SAES peripheral is connected to HUK and BHK over dedicated hardware busses that allows to wrap/unwrap keys based on specific protected hardware keys.
The SAES instance is used to decrypt the loaded firmware when device is in secured locked state.
3.1.1. On STM32MP13x lines More info.png[edit | edit source]
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Security SAES SAES ROM code allocation is managed with the bit 7 in OTP 9
3.1.2.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Security SAES SAES ROM code allocation is managed with the bit 8 in OTP 16
3.1.2.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
nonsecure
Security SAES SAES Assignment (single choice)
3.2.2. On STM32MP21x lines More info.png[edit | edit source]
3.2.2.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security SAES SAES OP-TEE
3.2.2.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.3. On STM32MP23x lines More info.png[edit | edit source]
3.2.3.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.3.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security SAES SAES OP-TEE n>
3.2.4. On STM32MP25x lines More info.png[edit | edit source]
3.2.4.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
3.2.4.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Below are listed the software frameworks and drivers managing the SAES peripheral for the embedded software components listed in the above tables.
