The purpose of this article is to explain how to configure the OP-TEE Calibration service using the device tree mechanism, relying on the bindings documentation, that is the description of the required and optional device-tree properties.
The device tree binding documents are stored in the given applicable components listed:
- OP-TEE OS:
- Calibration device tree bindings for STM32MP13x lines
and STM32MP15x lines
: documentation/devicetree/bindings/clock/st,stm32-calibration.yaml - Calibration device tree bindings for STM32MP2 series: documentation/devicetree/bindings/clock/st,stm32mp25-rcc.yaml (see hsi-calibration and msi-calibration subnodes).
3.1. DT configuration (STM32/SoC level)[edit | edit source]
The Calibration node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
3.1.1. STM32MP13x lines
By default, Timer12 is the counter used by both HSI/CSI calibration node at SoC level.
3.1.2. STM32MP15x lines
By default, Timer15 is the counter used by both HSI/CSI calibration node at SoC level.
3.1.3. STM32MP2 series[edit | edit source]
STM32MP2 series doesn't need to reserve a counter for HSI/MSI calibration, the flexclkgen engine is offering the capability to calculate the frequency of any internal clock via an internal module called clock frequency calculator.
The objective of this chapter is to explain how to enable and configure the calibration DT nodes for a board.
Configuration should be done in specific board device tree files (board dts file).
By default, each oscillator calibration (HSI/CSI/MSI) is disabled. It must be explicitly enable at board level.
Here is an example for CSI calibration activation for STM32MP1 series:
&csi_calibration {
status = "okay";
Here is an example for HSI calibration activation with a counter update for STM32MP1 series:
&hsi_calibration {
counter = <&timers15 0 7>;
status = "okay";
Here is an example of MSI calibration DT configuration for STM32MP2 series:
&msi_calibration {
status = "okay";
