How to install Node-RED
Warning DB.png Important
The Node-RED, subject of this article, is not part of STM32MPU ecosystem releases, for which ST provides some support.
This article only provides, as example, some helper guidelines (tips): you may need to make some adaptations depending on your system setup.
Node-RED® can be easily installed using the package repository for OpenSTLinux distribution service.
1. Node-RED direct installation
Execute the following commands to install Node-RED:
apt-get update
apt-get install node-red
Node-RED is automatically started and can be accessed remotely using your web browser:
http://<board IP @>:1880
Target and your host computer must be connected to the same network.
2. node-red-dashboard module
This module provides a set of nodes in Node-RED to quickly create a live data dashboard [1].
apt-get install node-red-dashboard
To access the Node-RED dashboard using your web browser:
http://<board IP @>:1880/ui
3. node-red-contrib-image-tools module
A Node-RED node to perform functions on images and decode barcodes [2].
apt-get install node-red-contrib-image-tools
4. References
