CEC device tree configuration
This article explains how to configure the CEC [1] when the peripheral is assigned to the Linux® OS.
The configuration is performed using the device tree mechanism [2].
The Device tree provides a hardware description of the CEC [1] used by the STM32 CEC Linux driver.
The CEC is represented by the STM32 CEC device tree bindings in the file Documentation/devicetree/bindings/media/cec/st,stm32-cec.yaml [3].
The CEC device tree node is declared in arch/arm/boot/dts/st/stm32mp151.dtsi [4]. It describes the hardware register address, clocks, interrupts and power domains.
		etzpc: bus@5c007000 {
			cec: cec@40016000 {
				compatible = "st,stm32-cec";
				reg = <0x40016000 0x400>;
				interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>;
				clocks = <&rcc CEC_K>, <&rcc CEC>;
				clock-names = "cec", "hdmi-cec";
				access-controllers = <&etzpc 38>;
				status = "disabled";
This device tree part is related to STM32 microprocessors. It must be kept as is, without being modified by the end-user. It is strongly advised not to change this configuration except for the "hdmi-cec" clock source.
The CEC device tree node contains the pinctrl description and the "okay" status:
&cec {
	pinctrl-names = "default";
	pinctrl-0 = <&cec_pins_a>;
	status = "okay";
You can find a full example of the STM32MP15 Evaluation board device tree in arch/arm/boot/dts/st/stm32mp157f-ev1.dts [5].
You can find a full example of the CEC pins [6] in the arch/arm/boot/dts/st/stm32mp15-pinctrl.dtsi [7]
	cec_pins_a: cec-0 {
		pins {
			pinmux = <STM32_PINMUX('A', 15, AF4)>;
			bias-disable;
			drive-open-drain;
			slew-rate = <0>;
	cec_sleep_pins_a: cec-sleep-0 {
		pins {
			pinmux = <STM32_PINMUX('A', 15, ANALOG)>; /* HDMI_CEC */
	cec_pins_b: cec-1 {
		pins {
			pinmux = <STM32_PINMUX('B', 6, AF5)>;
			bias-disable;
			drive-open-drain;
			slew-rate = <0>;
	cec_sleep_pins_b: cec-sleep-1 {
		pins {
			pinmux = <STM32_PINMUX('B', 6, ANALOG)>; /* HDMI_CEC */
