VDEC internal peripheral
  • briefly introduce the VDEC peripheral and its main features,
The VDEC (Video DECoder) peripheral is an hardware accelerator for video compressed content decoding such as H264 or VP8 bitstream and still-image content such as JPEG or WebP bitstream.
The VDEC peripheral is not used at boot time.
3.2.1. On STM32MP23x lines More info.png[edit | edit source]
The table below is applicable to any TD flavor (A35-TD or M33-TD) More info green.png.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Visual VDEC VDEC OP-TEE
3.2.2. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Below are listed the software frameworks and drivers managing the VDEC peripheral for the embedded software components listed in the above tables.
See also additional information in the VDEC device tree configuration article for Linux®.
