HASH internal peripheral
1. Peripheral overview[edit | edit source]
The HASH peripheral is used to compute a message digest.
The HASH peripheral is also able to give the HMAC[1] used for authentication using the same algorithm support.
1.1. On STM32MP13x lines More info.png and STM32MP2 series[edit | edit source]
Secure Hash algorithms supports:
  • SHA-1 [2]
  • SHA-2 [3]:
    • SHA-224
    • SHA-256
    • SHA-384
    • SHA-512
    • Truncated output SHA-512/224, SHA512/256
  • SHA-3 [4]:
    • SHA3-224
    • SHA3-256
    • SHA3-384
    • SHA3-512
    • SHAKE128 and 256
    • Keccak-based functions
  • HMAC support for all supported algorithm
1.2. On STM32MP15x lines More info.png[edit | edit source]
  • MD5 [5]
  • SHA-1 [2]
  • SHA-2 [3]:
    • SHA-224
    • SHA-256
2. Peripheral usage[edit | edit source]
2.1. Boot time assignment[edit | edit source]
The HASH instance is used as boot device to support binary authentication when device is in secured locked state.
2.1.1. On STM32MP13x lines More info.png[edit | edit source]
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Security HASH HASH
2.1.2. On STM32MP15x lines More info.png[edit | edit source]
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Security HASH HASH1
HASH2 not used at boot time.
2.1.3. On STM32MP21x lines More info.png[edit | edit source]
2.1.3.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Security HASH HASH1
2.1.3.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Security HASH HASH1
2.1.4. On STM32MP23x lines More info.png[edit | edit source]
2.1.4.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Security HASH HASH
2.1.4.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Security HASH HASH
2.1.5. On STM32MP25x lines More info.png[edit | edit source]
2.1.5.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Security HASH HASH
2.1.5.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Security HASH HASH
2.2. Runtime assignment[edit | edit source]
2.2.1. On STM32MP13x lines More info.png[edit | edit source]
nonsecure
Security HASH HASH Assignment (single choice)
2.2.2. On STM32MP15x lines More info.png[edit | edit source]
nonsecure
Cortex-M4
Security HASH HASH1 Assignment (single choice)
HASH2
2.2.3. On STM32MP21x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security HASH HASH1 OP-TEE
HASH2 OP-TEE
2.2.4. On STM32MP23x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security HASH HASH OP-TEE
2.2.5. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
3. Software frameworks and drivers[edit | edit source]
Below are listed the software frameworks and drivers managing the HASH peripheral for the embedded software components listed in the above tables.
4. How to assign and configure the peripheral[edit | edit source]
