How to record audio
Applicable for STM32MP13x lines, STM32MP15x lines, STM32MP21x lines, STM32MP25x lines
2. Audio record overview[edit | edit source]
The support of audio input interfaces is board dependent. Please, check available inputs using the "arecord -l" command.
The application audio streams are routed by default through the Pipewire[1] sound server. Pipewire exposes audio profiles, which are mapped on the ALSA sound card audio devices. The Pipewire server provides a command line interface to list audio profiles and to select one, in order to record from a specific audio interface.
In this article, the PulseAudio 'pactl' command is used in the examples. This is possible because the PipeWire sound server maintains backward compatibility with the former PulseAudio sound server through the pipewire-pulse package.
The applications that interact with the Weston framework have to be launched as "Weston" user instead of "root" user. The Pulseaudio commands, for instance, can be launched as follows:
su -l "weston" -c "pactl info"
3. Examples[edit | edit source]
3.1. Audio record from headset microphone input[edit | edit source]
3.1.1. Record from ALSA device[edit | edit source]
'record_codec' is an alias defined in /etc/asound.conf, for headset microphone input device.
arecord -D record_codec -f S16_LE -d 10 /tmp/rec.wav
3.1.2. Record via Pipewire[edit | edit source]
  • Configure Pipewire :
Change Pulseaudio default input source to 'analog_input':
The Pulseaudio analog_input is defined in /etc/pipewire/pipewire-pulse.conf.d/system.pa.conf configuration file.
pactl set-default-source analog_input
  • Start audio record :
The Pipewire device is the default one, so "-D pipewire" option can be omitted in the record command.
arecord -d 10 /tmp/rec.wav
3.2. Audio record from digital microphone input[edit | edit source]
3.2.1. Record from ALSA device[edit | edit source]
Start mono audio record from 'record_dmic0' ALSA device:
'record_dmic0' is an alias defined in /etc/asound.conf, for digital microphone U1 input device.
arecord -D record_dmic0 --rate 16000 --format S32_LE --channels 1 -d 10 /tmp/rec.wav
3.2.2. Record multiple digital microphones from a virtual ALSA device[edit | edit source]
Start stereo audio record from 'multi' ALSA device:
'multi' device, based on ALSA multi plugin[2], has to be defined in /etc/asound.conf file.
arecord -D multi --rate 16000 --format S32_LE --channels 2 -d 10 /tmp/rec.wav
3.2.3. Record via Pipewire[edit | edit source]
Change Pulseaudio default input source to 'dmic1_input':
The Pulseaudio dmic1_input is defined in /etc/pipewire/pipewire-pulse.conf.d/system.pa.conf configuration file.
pactl set-default-source dmic1_input
arecord -r 48000 -f S32_LE -c 2 -d 10 /tmp/rec.wav
3.3. Audio record from S/PDIF input[edit | edit source]
3.3.1. Get IEC958 status bits[edit | edit source]
The example below is given for sound card index 0. Check sound card index using the "aplay -l" command.
amixer -c 0 cget iface=PCM,name='IEC958 Capture Default'
3.3.2. Record from ALSA device[edit | edit source]
'record_spdif' is an alias defined in /etc/asound.conf, for S/PDIF input device.
A S/PDIF signal must be available on S/PDIF RCA input connector before starting the record command. The record rate must be set according to S/PDIF signal sampling rate.
arecord -D record_spdif --rate 48000 --format S32_LE --channels 2 -d 10 /tmp/rec.wav
3.3.3. Record via Pipewire[edit | edit source]
Change Pulseaudio default input source to 'iec958_input':
The Pulseaudio iec958_input is defined in /etc/pipewire/pipewire-pulse.conf.d/system.pa.conf configuration file.
pactl set-default-source iec958_input
arecord --rate 48000 --format S32_LE --channels 2 -d 10 /tmp/rec.wav
