X-LINUX-AZURE Distribution Package
Warning DB.png Important
This version of X-LINUX-AZURE expansion package is validated against the ecosystem release v6.0.0 More info.png . It has not been ported yet on ecosystem release v6.1.0 More info.png .
X-LINUX-AZURE Distribution Package is based on OpenSTLinux Distribution Package ecosystem release v6.0.0 More info.png .
1. Generate X-LINUX-AZURE OpenSTLinux distribution[edit | edit source]
With the following procedure, you can generate the complete distribution enabling the X-LINUX-AZURE expansion package.
This procedure is mandatory to use TPM or OP-TEE on the X-LINUX-AZURE expansion package.
1.1. Download the Distribution Package[edit | edit source]
  • Install the OpenSTLinux Distribution Package by following the dedicated article (STM32MPU Distribution Package) but do not initialize the OpenEmbedded environment (do not source the envsetup.sh).
1.2. Install X-LINUX-AZURE environment[edit | edit source]
1.2.1. Clone the meta-st-x-linux-azure Git repository[edit | edit source]
cd <Distribution Package installation directory>/layers/meta-st
git clone https://github.com/STMicroelectronics/meta-st-x-linux-azure.git -b v6.0.1
1.2.2. Clone the meta-st-x-linux-tpm Git repository[edit | edit source]
git clone https://github.com/STMicroelectronics/meta-st-x-linux-tpm.git -b 6.0.0
1.2.3. Clone the meta-iotedge Git repository and change layer compatibility[edit | edit source]
git clone https://github.com/Azure/meta-iotedge.git -b main
Validated on commit da7406a65f13e9f66453e9eccf6ab3df83bc48ec
1.2.4. Clone the meta-virtualization Git repository[edit | edit source]
git clone https://git.yoctoproject.org/meta-virtualization -b scarthgap
Validated on commit 7c78f4ef96020b702c027d179895c9f97179b4fc
1.2.5. Clone the meta-security Git repository[edit | edit source]
git clone https://git.yoctoproject.org/meta-security -b scarthgap
Validated on commit bc865c5276c2ab4031229916e8d7c20148dfbac3
1.2.6. Clone the meta-clang Git repository[edit | edit source]
git clone https://github.com/kraj/meta-clang.git -b scarthgap
Validated on commit 9fbfa9db33131abdf3870a94f00199eb53e276e5
1.2.7. Configure Yocto Project®[edit | edit source]
  • For a new environment
Source the build environment with the correct board and layers:
MACHINE=stm32mp2 DISTRO=openstlinux-weston BSP_DEPENDENCY='layers/meta-openembedded/meta-filesystems layers/meta-security layers/meta-security/meta-tpm layers/meta-st/meta-st-x-linux-tpm layers/meta-st/meta-st-x-linux-azure layers/meta-iotedge layers/meta-virtualization layers/meta-clang' source layers/meta-st/scripts/envsetup.sh
  • For an already installed environment
Add the layers to the Yocto environment:
bitbake-layers add-layer ../layers/meta-st/meta-st-x-linux-azure/ layers/meta-openembedded/meta-filesystems layers/meta-security/meta-tpm ../layers/meta-st/meta-st-x-linux-tpm ../layers/meta-iotedge ../layers/meta-security ../layers/meta-virtualization ../layers/meta-clang
1.3. Build the image[edit | edit source]
bitbake st-image-azure
Note that building the image might take a long time depending on the host computer performance.
1.4. Program the built image[edit | edit source]
Follow this link to see how to program the built image.
cd <Distribution Package installation directory>/build-openstlinuxweston-stm32mp2/tmp-glibc/deploy/images/stm32mp2
STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-azure/optee/FlashLayout_sdcard_stm32mp257f-dk-optee.tsv
STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-azure/optee/FlashLayout_sdcard_stm32mp257f-ev1-optee.tsv
2. How to use the X-LINUX-AZURE expansion package[edit | edit source]
Go to X-LINUX-AZURE_package_software_setup.
3. Main software modifications[edit | edit source]
Through the X-LINUX-AZURE Distribution Package, the OpenSTLinux distribution is mainly changed at two levels:
  • The Linux® kernel configuration and Device tree level with the X-LINUX-TPM expansion package integration.
  • User space bringing necessary libraries and tools to use Azure IoT Edge, OP-TEE, and the TPM expansion board features.
