X-LINUX-QT Developer Package
Applicable for STM32MP13x lines, STM32MP15x lines, STM32MP23x lines, STM32MP25x lines
Warning DB.png Important
This version of X-LINUX-QT expansion package is validated against the ecosystem release v6.0.0 More info.png . Porting on ecosystem release v6.1.0 More info.png is ongoing.
This article explains how to download and install the X-LINUX-QT developer package v2.1.0, compatible with OpenSTLinux developer package v6.0.0.
X-LINUX-QT developer package v2.1.0 supports both STM32MP2 series and STM32MP1 series series.
Installation commands given in this article for "stm32mp2" can be extended to "stm32mp1".
Needed prerequisites are described in X-LINUX-QT_expansion_package#Prerequisites.
2. Install the OpenSTLinux developer package[edit | edit source]
As prerequisite to X-LINUX-QT developer package installation, get and install the STM32MPU OpenSTLinux developer package v6.0.0.
The way to proceed is given in STM32MPU_Developer_Package#Developer_Package_step-by-step_overview article.
3. Install the X-LINUX-QT developer package[edit | edit source]
  • Download and install the X-LINUX-QT developer package
X-LINUX-QT developer package v2.1.0 release
Download
  • Go on st.com to download
    • en.en.SDK-x86_64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06-x-linux-qt-v2.1.0.tar.gz file for x86_64 host architecture
    • en.en.SDK-aarch64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06-x-linux-qt-v2.1.0.tar.gz file for arm64 host architecture
If you have already generated your own X-LINUX-QT developer package, jump to next step.
Installation
For x86_64 host architecture
  • Uncompress the tarball file to get the developer package installation script.
 mkdir -p ~/MySDK
 tar xvf en.en.SDK-x86_64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06-x-linux-qt-v2.1.0.tar.gz -C ~/MySDK
  • If needed, change the permissions on the SDK installation script so that it is executable.
 chmod +x ~/MySDK/stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06-x-linux-qt-v2.1.0/sdk/st-image-qt-openstlinux-weston-stm32mp2.rootfs-x86_64-toolchain-5.0.3-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06-addon-x-linux-qt-v2.1.0.sh
  • Run the SDK installation script.
 cd <working directory absolute path>/Developer-Package/SDK
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) SDK installer version 5.0.3-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06 - X-LINUX-QT version 2.1.0 SDK-Addon installer
Extracting X-LINUX-QT-Addon SDK................................................................................................Done.
Setting it up... Done.
Do you want to configure the Qt Creator for this SDK [y/n]? n
Qt Creator configuration will be ignored.
X-LINUX-QT-Addon SDK has been successfully set up and is ready to be used.
Alternative : If Qt Creator has been installed as explained in the "Prerequisites" chapter, it is now possible to configure it. For that, answer y to the next question:
Do you want to configure the Qt Creator for this SDK [y/n]? y
Please enter the directory where Qt Tools are installed (default: "/usr/lib, /usr/libexec"): /usr/libexec
Using /home/USER/Qt/Tools/sdktool/libexec/qtcreator/sdktool
Adding "Qt 6.6.3 for STM32MP2 ( 5.0.3-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06, X-LINUX-QT v2.1.0)" kit for Qt Design Studio... Done.
Adding "Qt 6.6.3 for STM32MP2 ( 5.0.3-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06, X-LINUX-QT v2.1.0)" kit for Qt Creator... Done.
For arm64 host architecture
 mkdir -p ~/MySDK
 tar xvf en.en.SDK-aarch64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06-x-linux-qt-v2.1.0.tar.gz -C ~/MySDK
 chmod +x ~/MySDK/stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06-x-linux-qt-v2.1.0/sdk/st-image-qt-openstlinux-weston-stm32mp2.rootfs-aarch64-toolchain-5.0.3-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06-addon-x-linux-qt-v2.1.0.sh
Extracting X-LINUX-QT-Addon SDK......................................................................................................... Done.
Alternative: If the Qt Creator has been installed preliminary as explained in the "Prerequisites" chapter, it is now possible to configure it. For that, answer y to the next question:
4. How to create QT applications using the X-LINUX-QT Developer Package[edit | edit source]
Articles explaining how to create some QT applications are available :
