STM32MP25 Evaluation boards - Starter Package for Android
Warning DB.png Important
OpenSTDroid is validated against the ecosystem release v5.1.0 . It has not been ported yet on ecosystem release v6.0.0 More info.png .
This article shows how to start up a STM32MP257x-EV1 More info green.png Evaluation boards (high-end development platforms for the STM32MP25 microprocessor devices). It is valid for the STM32MP257F-EV1 More info green.png Evaluation boards: the part numbers are specified in the STM32MP25 microprocessor part numbers article.
1. Starter Package content[edit | edit source]
This Starter Package provides:
  • the OpenSTDroid distribution binaries
  • the partition layout required to flash the device with STM32CubeProgrammer
2. Checking the material[edit | edit source]
Mandatory
PC Linux or Windows operating systems. See PC prerequisites for more details on the required configurations
STM32MP257x-EV1 evaluation board High-end development platform for the STM32MP25 microprocessor device including:
microSDTM card It is populated with OpenSTLinux distribution (Linux software), and provides extra storage capacity. An 8-Gbyte minimum microSD card is needed
USB type-C cable It connects the STM32MP257x-EV1 evaluation board to the PC through the USB type-C (ST-LINK/V3) connector
USB type-C cable It connects the STM32MP257x-EV1 evaluation board to a USB OTG device through the USB micro-AB connector
Optional
LCD screen Several types of screen are possible : LVDS, DSI, or HDMI
Power supply (Optional) Power supply block (5 V, 3A) for the MB1936 board.
USB keyboard and mouse Thanks to the USB type A connectors, the STM32MP257x-EV1 Evaluation board can be equipped with a full-size keyboard and mouse
Ethernet cable It can connect the STM32MP257x-EV1 evaluation board to a network through the RJ45 connector
RS232 cable It can connect the STM32MP257x-EV1 evaluation board to the PC through the UART connector as an alternative of the ST-LINK/V2-1 connection
CAN cable It can connect the STM32MP257x-EV1 evaluation board to CAN devices through the CAN FD/TT connectors
Trace cable It can connect the STM32MP257x-EV1 evaluation board to an external tool through the Trace connector
JTAG cable It can connect the STM32MP257x-EV1 evaluation board to an external tool through the JTAG connector
Optionally, devices and extension boards might be plugged to the STM32MP257x-EV1 evaluation board thanks to connectors such as:
  • the GPIO expansion connector
  • the PCIe connector
  • the Mikro bus connector
The following figure shows the material not included in STM32MP25 Evaluation board package which is used in this Starter Package.
Recommended material for this Starter Package
3. Assembling the board[edit | edit source]
The STM32MP257x-EV1 Evaluation board packages (STM32MP257F-EV1 More info green.png), completed by the B-CAMS-IMX package, include the items listed below.
STM32MP257F-EV1 shown here (picture is not contractual)
Position Description
1 MB1936 main board
2 7” LVDS WSVGA display with touch panel (EDT ETML0700Z9NDHA panel) (optional)
3 LVDS display cable (optional)
4 MB1854 board AI camera (not part of the STM32MP257x-EV1 Evaluation board package; provided with the B-CAMS-IMX package) (optional)
5 Camera board FFC (not part of the STM32MP257x-EV1 Evaluation board package; provided with the B-CAMS-IMX package) (optional)
LVDS displays and CSI cameras are available for purchase to complete this basic setup.
The complete set looks like this:
STM32MP257x-EV1 Evaluation board assembly
3.1. Connecting the LVDS display to the board[edit | edit source]
Display board assembly (picture is not contractual)
  • Check the cable orientation shown above using the black mark and the white twisted pairs.
  • Find the LVDS ports on the STM32MP257x-DK Discovery kit (CN2) and the display (CN1). The LVDS display box contains one cable.
  • Insert the cable into each port as shown below:
3.2. Connecting the MB1854 camera board to the board[edit | edit source]
Camera board assembly (picture is not contractual)
  • Find the camera ports on the STM32MP257x-EV1 Evaluation board (CN4) and MB1854 (CN1). One FFC is provided in the camera box.
  • For each port:
    • Pull the black plastic (#1 in the image below) lightly to insert the contact side of the FFC towards the board (#2 in the image below).
    • Push the black plastic carefully to hold the FFC (#3 in the image below).
3.3. STM32MP257x-EV1 Evaluation board assembled[edit | edit source]
4. Installing the tools[edit | edit source]
4.1. Installing the STM32CubeProgrammer tool[edit | edit source]
Download
Version v2.20.0
unzip en.stm32cubeprog.zip
Installation
$> ./SetupSTM32CubeProgrammer-2.20.0.linux
User manual
Detailed release note
4.2. Preparing the USB serial link for flashing[edit | edit source]
  • For Windows host PC:
5. Downloading the image and flashing it on the board[edit | edit source]
5.1. Image download[edit | edit source]
STM32MPU distribution for Android™
Tag Flash device Link Release note
st-android-13.0.0-2024-07-31 eMMC
Under construction.png Coming soon
st-android-13.0.0-2024-07-31 release note
Installation
  • Go to the host PC directory where to install the Starter Package (<Starter Package installation directory>); for example:
cd <working directory path>/Android-Starter-Package
  • Download the tarball file (*.tar.gz)) in this directory
  • Uncompress the tarball file to get the binaries for the different partitions of the image, and the flash layout files:
tar xvf st-android-<version>-<date>-stm32mp257f-ev1-<flash device>-starter.tar.gz
5.2. Flashing the eMMC images[edit | edit source]
The STM32CubeProgrammer tool is used to flash the STM32MP25 Evaluation board with the downloaded image.
Several flash devices (microSD, eMMC...) are available on this board: see the STM32 MPU Flash mapping for Android article to know more about the supported Flash memory technologies, and the flash partitions. The steps below consider the eMMC as the flash device.
As explained in the boot chain overview, the optee boot chain is the default solution delivered by STMicroelectronics. Thus, the steps below use the image for the optee boot chain.
Let's flash the downloaded image on the eMMC card:
  • Set the boot switches to the off position (boot from UART/USB).
Boot from UART/USB
  • Connect the USB type-C (OTG) port (4) to the host PC that contains the downloaded image.
  • Insert the delivered microSD card into the dedicated slot (5).
  • Connect the USB type-C (power supply) port (1) to the power connector or a host PC, and check the power jumper position.
  • Press the reset button (7) to reset the board.
Evaluation board connections for flashing
STM32MP257A-EV1 shown here (picture is not contractual)
  • Go to the Starter Package directory that contains the binaries and the flash layout files.
cd <Starter Package installation directory>/st-android-<version>-<date>-stm32mp257f-ev1-<flash device>-starter
The commands below are for a Linux host PC; however, they are similar for a Windows host PC except that STM32_Programmer_CLI is replaced by STM32_Programmer_CLI.exe.
  • Check that the STM32CubeProgrammer tool is installed and accessible; if not, go to the installation procedure (installing the tools).
STM32_Programmer_CLI --h
  • Get the device port location for the USB link.
STM32_Programmer_CLI -l usb
=====  DFU Interface   =====
  Device Index           : USB1
  USB Bus Number         : 003
  USB Address Number     : 005
  Product ID             : DFU in HS Mode @Device ID /0x505, @Revision ID /0x2000
  Serial number          : 001900364136500100373653
  Device ID              : 0x0505
  • Flash the eMMC with the image for the trusted boot chain.
STM32_Programmer_CLI -c port=usb1 -w flashlayout/FlashLayout_emmc_optee.tsv
This operation takes several minutes.
See the STM32CubeProgrammer article to know more about the flashing operation.
6. Booting the board[edit | edit source]
Now that the image is flashed on the STM32MP257x-EV1 Evaluation board, let's finalize the system configuration:
  • Step 0: Check that the LVDS display board is well connected.
  • Step 1: Check the configuration of the switches and jumpers:
    • The boot related switches must be configured so that the device (e.g. eMMC) on which the image has been flashed is selected as boot source.
The figure below shows the boot switches for the recommended boot from eMMC.
Boot from eMMC
  • Step 2: (optionally) Connect a USB keyboard and/or a USB mouse (not provided) using the USB type-A ports (3 in the picture below).
  • Step 3: (optionally) Connect an Ethernet cable (not provided) to the dedicated connector (2).
USB Power Delivery Type-C (Power or  STLINK)ETHERNET 2/PHY ETH2 (Ethernet)2 x USB type A (host) (such as a mouse or keyboard USB driver)USB2.0 DRD Type-C  (programmable through CubeProgrammer)microSD<sup>™</sup> card slotMB1936 5V/3A power supply jack (Power)RESET button
STM32MP257x-EV1 Evaluation board connections
  • Step 4: Insert a microSD card into the dedicated slot (5).
  • Step 5: Check the power jumper position and connect:
    • either the USB Power – TypeC cable to the connector (1).
    • or power supply (5V, 3A) to the power connector (6) of the MB1936
  • Step 6: (optionally) Install and configure a remote Terminal program (e.g. Minicom on Ubuntu Linux PC or Tera Term on Windows PC) onto your host PC, and connect the ST-LINK/V3 USB type-C port (1) to a host PC that runs a Terminal program with ST-LINK/V3 virtual port.
  • Step 7: Press the reset button (7) to reset the board.
The board boots and the system is available after few seconds.
7. How to go further?[edit | edit source]
Now that the image is flashed on the STM32MP25 Evaluation board, you might want to switch to the STM32MPU Distribution Package for Android, in order to modify or tune the STM32MPU Embedded Software distribution with your own developments.
