DDRPERFM internal peripheral
  • briefly introduce the DDRPERFM peripheral and its main features,
The DDRPERFM peripheral is used to count various DDRCTRL events, for performance analysis.
The read, write and time counters are certainly the ones that are the most useful from user point of view, since they allow computing the DDR read and write throughputs.
Other counters are available in order to monitor the DDR controller arbitration dynamic, refresh commands and low-power management.
The DDRPERFM peripheral is not used at boot time.
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Trace & Debug DDRPERFM DDRPERFM
nonsecure
nonsecure
Cortex-M4
3.2.3. On STM32MP21x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Trace & Debug DDRPERFM DDRPERFM OP-TEE Part of DDRSS protected by RCC DDRPERFM_CFGR
3.2.4. On STM32MP23x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Trace & Debug DDRPERFM DDRPERFM OP-TEE Part of DDRSS protected by RCC DDR_CFGR
3.2.5. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Below are listed the software frameworks and drivers managing the DDRPERFM peripheral for the embedded software components listed in the above tables.
Refer to How to measure the DDR throughput to learn how to use the DDRPERFM internal peripheral via the perf tool.
