COMBOPHY internal peripheral
  • briefly introduce the COMBOPHY peripheral and its main features,
The COMBOPHY peripheral is used as protocol PHY for the USB3DR or PCIe. It provides:
  • the physical layer for differential Rx/Tx data encoding,
  • the 100 MHz differential reference clock provided to the pins and the PCIe controller.
The 100 MHz PCIe internal reference clock can be sourced directly from:
  • the PLL with a 20 MHz the crystal oscillator (HSE) input,
  • an external PCIe 100 MHz differential reference clock (with SSC).
USB3DR and PCIe modes are exclusive
COMBOPHY Block Diagram
3.1.1. On STM32MP25x lines More info.png[edit | edit source]
3.1.1.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
High speed interface COMBOPHY COMBOPHY
3.1.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
High speed interface COMBOPHY COMBOPHY OP-TEE COMBOPHY can be assigned to either the USB3DR or the PCIe.
Below are listed the software frameworks and drivers managing the COMBOPHY peripheral for the embedded software components listed in the above tables.
For Linux kernel, please refer to the COMBOPHY device tree configuration
