Arm Cortex-A35
  • briefly introduce the Arm® Cortex®-A35 and its main features,
The Arm Cortex-A35 can be instantiated several times into a single cluster:
  • The STM32MP25 processor is a Cortex-A35 cluster embedding one or two core(s), depending on the selected line.
  • The STM32MP23 processor is a cortex-A35 cluster embedding one or two core(s), depending on the selected line.
  • The STM32MP21 processor is a cortex-A35 cluster embedding one core, depending on the selected line.
The Cortex-A35 processor is Arm's most power-efficient application processor capable of seamlessly supporting 32-bit and 64-bit code. It fully supports ARMv8-A architecture, with following features:
  • AArch32 for full backward compatibility with Arm7
  • AArch64 for 64-bit support
  • Trustzone security
  • Hardware virtualization support
  • Neon Advanced SIMD and floating-point architecture support
  • Memory management unit (MMU)
  • Separate Level 1 (L1) data- and instruction-side memory systems
  • Unified Level 2 (L2) memory system that provides Cortex-A35 subsystem memory coherency
The Cortex-A35 supports a nonsecure and a secure modes that define two hardware execution contexts, named Cortex-A35 nonsecure and Cortex-A35 secure.
As soon as the STM32MP2 is powered up, The Cortex-A35 starts to execute the ROM code, which is the first stage of the boot chain.
With A35-TD flavor More info green.png, it then executes the FSBL TF-A in secure mode before jumping to the SSBL U-Boot in nonsecure mode.
With M33-TD flavor More info green.png, it then enter in low power and the Arm Cortex-M33 becomes the boot processor. As soon as the system is initialized by the Arm cortex-M33, it sends a SEV signal to wakeup the Arm cortex-A35.
3.1.1.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Core/Processors Arm® Cortex®-A35 Arm® Cortex®-A35
3.1.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Core/Processors Arm® Cortex®-A35 Arm® Cortex®-A35 Can be started by MCUboot.
Running the OpenSTLinux distribution.
The Cortex-A35 supports Cortex-A35 secure and Cortex-A35 nonsecure contexts.
With A35-TD flavor More info green.png, it cannot be assigned but, it manages all the peripherals assigned to those contexts.
At runtime, Cortex-A35 is executing OpenSTLinux BSP distribution. Cortex-A35 executes the secure monitor TF-A BL31 and secure OS OP-TEE in secure mode and Linux kernel in nonsecure mode
3.2.1. On STM32MP21x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core/Processors Arm® Cortex®-A35 Arm® Cortex®-A35 OP-TEE
TF-A BL31
In M33-TD flavor More info green.png, Cortex-A35 can be started by TF-M or by STM32CubeMP2.
3.2.2. On STM32MP23x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
TF-A BL31
3.2.3. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
TF-A BL31
All the software components executed by the Cortex-A35, at boot time and at runtime, constitute the OpenSTLinux distribution.
Below are listed the software frameworks and drivers managing the Arm® Cortex®-A35 for the embedded software components listed in the above tables.
The Cortex-A35 configuration is done by the various components running on it, according to build-time parameters, and also information from the device tree.
Refer to Arm website[1] for more detailed information on this core.
