This article explains how to configure the VENC [1] when the peripheral is assigned to the Linux® OS.
The configuration is performed using the device tree mechanism [2].
The Device tree provides a hardware description of the VENC [1] used by the STM32 VENC Linux driver.
The VENC is represented by the STM32 VDEC device tree bindings file: st,stm32mp25-video-codec.yaml .
3.1. DT configuration (STM32/SoC level)[edit | edit source]
The VENC node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
For STM32MP25x lines
, the VENC device tree node is declared in arch/arm64/boot/dts/st/stm32mp255.dtsi :
&rifsc {
venc: venc@480e0000 {
compatible = "st,stm32mp25-venc";
reg = <0x480e0000 0x800>;
resets = <&rcc VENC_R>;
interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&rcc CK_BUS_VENC>;
access-controllers = <&rifsc 90>;
power-domains = <&CLUSTER_PD>;
, the STM32 VENC is already enabled by default in stm32mp255.dtsi , so there is no need to enable it at board level.
