STM32MP13 VREFBUF internal peripheral
  • briefly introduce the VREFBUF peripheral and its main features,
The VREFBUF is supplied via the VDDA pin. When enabled, it can provide a reference voltage in the range of: 1,65V, 1,8V, 2,048V or 2,5V. The VREFBUF can be used to provide an analog voltage reference for:
Refer to the STM32MP13 reference manuals for the complete list of features, and to the software frameworks and drivers, introduced below, to see which features are implemented.
3.1.1. On STM32MP13x lines More info.png[edit | edit source]
The VREFBUF is usually not used at boot time. But it may be needed by the SSBL (see Boot chain overview), to supply the internal ADC for example.
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Analog VREFBUF VREFBUF OP-TEE offers SCMI regulator service to manage VREFBUF
nonsecure
Analog VREFBUF VREFBUF Assignment (single choice)
As soon as one VREFBUF client peripheral (ADC1 or ADC2) is set secure, the VREFBUF should be set secure with ETZPC configuration.
In OpenSTlinux, VREFBUF is only managed by OP-TEE exported through SCMI even if all ADC are non-secured.
Below are listed the software frameworks and drivers managing the VREFBUF peripheral for the embedded software components listed in the above tables.
5.1. DT configuration example[edit | edit source]
In OP-TEE device tree:
 &etzpc {
 	st,decprot = <
 		DECPROT(STM32MP1_ETZPC_VREFBUF_ID, DECPROT_S_RW, DECPROT_UNLOCK)
 &scmi_regu {
 	scmi_vrefbuf: voltd-vrefbuf {
 		reg = <VOLTD_SCMI_VREFBUF>;
 		voltd-supply = <&vrefbuf>;
 &vrefbuf {
 	vdda-supply = <&vdd>;
 	status = "okay";
In Linux device tree:
 &adc_1 {
 	vref-supply = <&scmi_vrefbuf>;
 	status = "okay";
 &scmi_regu {
 		regulator-name = "vrefbuf";
 		regulator-min-microvolt = <2500000>;
 		regulator-max-microvolt = <2500000>;
