STM32MP2 SRAM internal memory
  • briefly introduce the SRAM internal memory peripheral and its main features,
On STM32MP21x lines More info.png:
  • The SRAM peripheral is 64-Kbyte wide and physically near to the Cortex-M33 for optimized performances from this core. The 64BK fits in only one bank: the SRAM1.
On STM32MP23x lines More info.png and STM32MP25x lines More info.png:
  • The SRAM peripheral is 256-Kbyte wide and physically near to the Cortex-M33 for optimized performances from this core.
  • It is split into two separate banks:
    • SRAM1 (128 Kbytes)
    • SRAM2 (128 Kbytes)
Each bank is protected via a RISAB memory firewall allowing to define 4-Kbyte granularity regions with different access rights. Each region could be assigned to different execution contexts. Each bank also owns automatic clock gating (for power management optimization) which can be linked:
  • either on one processor low power state if the bank is only assigned to this processor,
  • or on system low power state if the bank is assigned to several processors.
Banks content is preserved in (LPLV)Stop1/2 low power mode but it is lost in Standby low power mode as not supplied.
Moreover, SRAM1 is protected by tamper detection circuit and is erased by hardware in case of tamper detection.
This chapter is applicable in the scope of the OpenSTLinux BSP running on the Arm Cortex-A processor(s), and the STM32CubeMPU Package running on the Arm Cortex-M processor.
The ROM code uses the MCU SRAM1 to store the USB context during a boot on USB for Flash programming (with STM32CubeProgrammer).
In A35-TD flavor More info green.png, Cortex-A35 FSBL (TF-A BL2) uses SRAM1 during cold boot for:
  • DDR firmware loading
  • mbedTLS heap
  • OTP shadow
3.1.1. On STM32MP21x lines More info.png[edit | edit source]
3.1.1.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Core/RAM SRAM SRAM1 Used during cold boot by TF-A BL2 for DDR firmware loading
3.1.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Core/RAM SRAM SRAM1 Used during boot by MCUboot for his memory stack.
3.1.2. On STM32MP23x lines More info.png[edit | edit source]
3.1.2.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
SRAM2
3.1.2.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
SRAM2 Used during boot by MCUboot to host DDR buffers used for DDR firmware installation
3.1.3. On STM32MP25x lines More info.png[edit | edit source]
3.1.3.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
SRAM2
3.1.3.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
In A35-TD flavor More info green.png: Cortex-A35 Secure OS(OP-TEE) uses SRAM1 for OTP shadow.
In M33-TD flavor More info green.png:
  • SRAM1 is used to manage exchanges between both cores:
    • A dedicated mirror is used to share the BSEC non secret OTP that are necessary for both cores to configure the platform. The area is a non-secure area that can be accessible by all cores but limited as read only partition.
    • SCMI CID1 buffer to exchange messages between the CID1 clients (secure, non-secure) and the server.
    • PSA buffer to exchange between client and the CID2 server.
    • A TFM_SHARED_DATA area to exchange data between MCUboot and TFM.
    • CM33_SRAM1 as reserved area for default M33 usage (rest of the memory).
3.2.1. On STM32MP21x lines More info.png[edit | edit source]
3.2.1.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core/RAM SRAM SRAM1 OP-TEE
BL31
OP-TEE populate OTP shadow region
3.2.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
BL31
Bsec mirror, SCMI CID1 exchange area, PSA buffer. See STM32MP21_memory_mapping
3.2.2. On STM32MP23x lines More info.png[edit | edit source]
3.2.2.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
BL31
SRAM2 OP-TEE
BL31
3.2.2.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
BL31
SRAM2 OP-TEE
BL31
3.2.3. On STM32MP25x lines More info.png[edit | edit source]
3.2.3.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
BL31
SRAM2 OP-TEE
BL31
3.2.3.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
BL31
SRAM2 OP-TEE
BL31
Below are listed the software frameworks and drivers using the SRAM peripheral for the embedded software components listed in the above tables.
  • Linux: reserved memory, that is used by the dmaengine (for DMA buffers management) or RPMsg for interprocess communication with the Arm® Cortex®-M processor in case of A35-TD flavor More info green.png.
The default assignment set in STMicroelectronics distribution is in line with the platform memory mapping that can be adapted by the platform user.
