STM32MP23 peripherals overview for M33-TD flavor
Applicable for STM32MP23x lines
Info white.png Trusted domain applicability
This article is only applicable to M33-TD flavor More info green.png of STM32MP2 series
This article lists all internal peripherals embedded in STM32MP23x lines More info.png and shows the assignment possibilities to the execution contexts for each one of them.
From this article, you can also access to individual peripheral articles with information related to the overview and configuration aspects.
1. Internal peripherals overview[edit | edit source]
The figure below shows all peripherals embedded in STM32MP23x lines More info.png, grouped per functional domains that are reused in many places of this wiki to structure the articles.
Several execution contexts exist on STM32MP23x lines More info.png[1], corresponding to the different Arm cores and associated security modes:
  •  Arm dual core Cortex-A35 secure  (Trustzone), running ROM code and TF-A BL2 at boot time, and running OP-TEE and/or TF-A BL31 at runtime
  •  Arm dual core Cortex-A35 non secure , running U-Boot at boot time, and running Linux at runtime
  •  Arm Cortex-M33 secure  (Trustzone), running TF-M
  •  Arm Cortex-M33 non-secure , running STM32Cube
The legend below shows how assigned and shared peripherals are identified in the assignment diagram that follows:
  • When a peripheral box owns execution context color, that means the assignment of this peripheral is fixed by hardware to the execution context.
  • When a peripheral box owns a mix of two execution colors that means this peripheral is shared by hardware between the two execution contexts.
  • When a peripheral box has dark gray color, that means this peripheral is protected by RIF and could be assigned to any execution context.
  • When a peripheral box has light gray color, that means this peripheral is a RIF-aware peripheral. This peripheral owns several features which can be assigned independently to any execution context.
Internal peripheral assignment tables list assignment capabilities for each peripheral.
Both the diagram below and the following summary tables (in Internal peripherals runtime assignment and Internal peripherals boot time assignment chapters below) are clickable in order to jump to each peripheral overview articles and get more detailed information (like software frameworks used to control them). They list STMicroelectronics recommendations. The STM32MP23 reference manual [2] may expose more possibilities than what is shown here.
RTCFMCSAESDCMII3CSAISPDIF-RXI2SUSARTUARTADCVREFBUFUSBHETHLPTIMTIMEXTIIPCCI2CCortex-M33 TDCIDGPUDSILTDCIWDG2IWDG3SysCfgHPDMAUSB3DRCRCCRYPRNGHASHRCCBSECTAMPHDPCoresightGICSTGENCortex-A35DTSPWROCTOSPIFDCANSDMMCIWDG4GPIOA-IDBGMCUIWDG1CSIGPIO-ZOTFDECRISAFRIFSCRISABNVICLPUARTHSEMMDFWWDGOCTOSPIMLVDSDCMIPPVDECPKAUCPDSERCUSB2PHYSYSRAMRETRAMDDR CTRLBKPSRAMSRAMSPI
STM32MP23 internal peripherals overview
2. Internal peripherals boot time assignment[edit | edit source]
ADF internal peripheral
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Core/Processors Arm® Cortex®-A35 Arm® Cortex®-A35 Can be started by MCUboot.
Running the OpenSTLinux distribution.
Core/Processors Arm® Cortex®-M33 Arm® Cortex®-M33
Analog VREFBUF VREFBUF TF-M offers SCMI regulator service to manage VREFBUF
Analog ADC ADC12
ADC3
Analog MDF MDF1
Coprocessor IPCC Info.png IPCC1 Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
Core STGEN STGEN Read-only
(STGENR)
Core RTC Info.png RTC Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
Core/DMA HPDMA Info.png HPDMAx (x = 1 to 3) Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
Core/DMA LPDMA Info.png LPDMA1 Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
Core/Interrupts EXTI Info.png EXTI1 Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
EXTI2 Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
Core/IOs GPIO Info.png GPIOA-K Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
GPIOZ Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
Core/RAM SYSRAM SYSRAM
Core/RAM DDRCTRL & DDRPHYC DDR Assignment is controlled by the RCC RIF 104 resource that also include the PLL2 control.
Core/RAM SRAM SRAM1 Used during boot by MCUboot for his memory stack.
SRAM2 Used during boot by MCUboot to host DDR buffers used for DDR firmware installation
Core/Timers TIM TIMx (x = 1 to 8, 10 to 17)
Core/Timers LPTIM LPTIMx (x = 1 to 5)
Core/Watchdog IWDG IWDG1
IWDG2
IWDG3
IWDG4
Core/Watchdog WWDG WWDG1
High speed interface USB3DR USB3DR The USB3DR can be used by U-Boot with command line tools.
High speed interface USBH USBH
High speed interface UCPD UCPD1
High speed interface USB2PHY USB2PHY1 USB2PHY1 can be used in U-boot by USBH with command line tools.
USB2PHY2 USB2PHY2 can be used in U-boot by USB3DR with command line tools.
Low speed interface USART UART4
UART5
UART7
USART1
USART2
USART3
USART6
Low speed interface LPUART LPUART1
Low speed interface I2C I2C1
I2C2
I2C7
I2C8
Low speed interface I3C I3C1
I3C2
I3C4
Mass storage OCTOSPI OCTOSPI1
OCTOSPI2
Mass storage OCTOSPIM OCTOSPIM
Mass storage FMC Info.png FMC Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
Mass storage SDMMC SDMMC1
SDMMC2
SDMMC3
Power & Thermal RCC Info.png RCC Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
For internal peripherals protected by a RISUP, the protection for reset and clock gating control is inherited from RIFSC configuration
RCC peripheral is used by all boot components. More info here
Power & Thermal PWR Info.png PWR Shareable at internal peripheral level thanks to the RIF:
Power & Thermal DTS DTS
Security BSEC BSEC
Security RNG RNG
Security HASH HASH
Security CRYP CRYP1 ROM code allocation is managed with the bit 8 in OTP 16
CRYP2
Security SAES SAES ROM code allocation is managed with the bit 8 in OTP 16
Security TAMP Info.png TAMP Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
Security OTFDEC OTFDEC1
OTFDEC2
Security PKA PKA
Security RIFSC RIFSC
Security RISAB RISAB1
RISAB2
RISAB3 Used by ROM code only in serial boot for USB buffer management
RISAB4 Used by MCUBoot for the DDR firmware buffer
RISAB5 Used by ROM code only during cold boot
RISAB6
Security RISAF RISAF1
RISAF2
RISAF4 FSBL MCUboot configures Cortex-M secure and encrypted memory regions
Trace & debug SERC SERC
Visual DSI Info.png DSI Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
Visual LTDC LTDC_CMN
LTDC_L1L2
LTDC_L3
LTDC_ROT
Visual LVDS LVDS
3. Internal peripherals runtime assignment[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core/Processors Arm® Cortex®-A35 Arm® Cortex®-A35 OP-TEE
TF-A BL31
In M33-TD flavor More info green.png, Cortex-A35 can be started by TF-M or by STM32CubeMP2.
Analog ADC ADC12 OP-TEE
ADC3 OP-TEE
Analog MDF MDF1 OP-TEE
Audio SPDIFRX SPDIFRX OP-TEE
Audio SAI SAI1 OP-TEE
SAI2 OP-TEE
SAI3 OP-TEE
SAI4 OP-TEE
Coprocessor IPCC Info.png IPCC1 Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
Core STGEN STGEN OP-TEE
TF-A BL31
Read-only
(STGENR)
Core RTC Info.png RTC Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature RTC is mandatory to resynchronize STGEN after exiting low-power modes.
HPDMAx (x = 1 to 3) Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
LPDMA Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
Core/Interrupts EXTI Info.png EXTI1 Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
EXTI2 Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
Core/IOs GPIO Info.png GPIOA-K Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
GPIOZ Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
Core/RAM SYSRAM SYSRAM BL31
OP-TEE
Cortex-A35 secure section required for low power entry and exit
Core/RAM SRAM SRAM1 OP-TEE
BL31
Bsec mirror, SCMI CID1 exchange area, PSA buffer. See STM32MP21_memory_mapping
SRAM2 OP-TEE
BL31
Core/Timers TIM TIMx (x = 1 to 8, 10 to 17) OP-TEE
Core/Timers LPTIM LPTIM1 OP-TEE LPTIM1 can be used for HSE monitoring.
LPTIM2 OP-TEE
LPTIM3 OP-TEE LPTIMy (y = 3, 4, 5) can be used for scheduling in low power modes by Linux
LPTIM4 OP-TEE LPTIMy (y = 3, 4, 5) can be used for scheduling in low power modes by Linux
LPTIM5 OP-TEE LPTIMy (y = 3, 4, 5) can be used for scheduling in low power modes by Linux
Core/Watchdog IWDG IWDG1 OP-TEE
TF-A BL31
IWDG2 OP-TEE
TF-A BL31
IWDG3
IWDG4
High speed interface USB3DR USB3DR OP-TEE The USB3DR running at USB2 speed.
High speed interface USBH USBH OP-TEE
High speed interface UCPD UCPD1 OP-TEE
High speed interface USB2PHY USB2PHY1 OP-TEE
TF-A BL31
Allocation inherited from USBH
USB2PHY2 OP-TEE
TF-A BL31
Allocation inherited from USB3DR
Low speed interface USART UART4 OP-TEE
TF-A BL31
UART5 OP-TEE
TF-A BL31
UART7 OP-TEE
TF-A BL31
USART1 OP-TEE
TF-A BL31
USART2 OP-TEE
TF-A BL31
USART3 OP-TEE
TF-A BL31
USART6 OP-TEE
TF-A BL31
Low speed interface LPUART LPUART1 OP-TEE
TF-A BL31
Low speed interface I2C I2C1 OP-TEE
TF-A BL31
I2C2 OP-TEE
TF-A BL31
I2C7 OP-TEE
TF-A BL31
Used for PMIC control on ST boards.
I2C8 OP-TEE
TF-A BL31
Low speed interface I3C I3C1 OP-TEE
TF-A BL31
I3C2 OP-TEE
TF-A BL31
I3C4 OP-TEE
TF-A BL31
Mass storage OCTOSPI OCTOSPI1 OP-TEE OP-TEE need to access OCTOSPI1 at boot time to set OSPIM mode
OCTOSPI2 OP-TEE OP-TEE need to access OCTOSPI2 at boot time to set OSPIM mode
Mass storage OCTOSPIM OCTOSPIM OP-TEE
Mass storage FMC Info.png FMC Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
Mass storage SDMMC SDMMC1 OP-TEE
SDMMC2 OP-TEE
SDMMC3 OP-TEE
Power & Thermal RCC Info.png RCC Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature.
For internal peripherals protected by a RISUP, the protection for reset and clock gating control is inherited from RIFSC configuration.
RCC peripheral is used by all software components. More info here.
The Cortex-M secure OS TF-M controls the system resources and provides SCMI services
Power & Thermal DTS DTS TF-A BL31
OP-TEE
Security BSEC BSEC
Security RNG RNG OP-TEE
Security HASH HASH OP-TEE
Security CRYP CRYP1 OP-TEE
CRYP2 OP-TEE
Security CRC CRC OP-TEE
Security SAES SAES OP-TEE n>
Security TAMP Info.png TAMP Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
Security OTFDEC OTFDEC1 OP-TEE
OTFDEC2 OP-TEE
Security RIFSC RIFSC OP-TEE
Security RISAB RISAB1 OP-TEE
RISAB2 OP-TEE
RISAB3 OP-TEE
RISAB4 OP-TEE
RISAB5 OP-TEE
RISAB6 OP-TEE
Security RISAF RISAF1 OP-TEE TF-M configures all regions
RISAF2 OP-TEE TF-M configures all regions
RISAF4 OP-TEE TF-M configures all regions all regions except its own
Trace & debug SERC SERC OP-TEE
Trace & Debug HDP HDP OP-TEE
Visual GPU GPU OP-TEE
Visual DSI Info.png DSI Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
Visual LTDC LTDC_CMN OP-TEE
LTDC_L1L2 OP-TEE
LTDC_L3 OP-TEE
LTDC_ROT OP-TEE
Visual DCMI DCMI OP-TEE
Visual CSI CSI OP-TEE
Visual LVDS LVDS OP-TEE
Visual DCMIPP DCMIPP OP-TEE
Visual VDEC VDEC OP-TEE
