DTS internal peripheral
  • briefly introduce the DTS peripheral and its main features,
The Digital temperature sensor (DTS) peripheral is used to monitor the device temperature and take some preventive action (like frequency scaling or peripheral disabling) in case it is becoming too high and before destroying the component.
The DTS peripheral is not used at boot time.
3.1.2.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Power & Thermal DTS DTS
3.1.2.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
nonsecure
nonsecure
Cortex-M4
3.2.3. On STM32MP21x lines More info.png and STM32MP23x lines More info.png[edit | edit source]
The present chapter describes STMicroelectronics recommendations or choice of implementation. Additional possibilities might be described in STM32MP21 reference manuals and in STM32MP23 reference manuals.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Power & Thermal DTS DTS TF-A BL31
OP-TEE
3.2.4. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
OP-TEE
Below are listed the software frameworks and drivers managing the DTS peripheral for the embedded software components listed in the above tables.
