RNG internal peripheral
  • Briefly introduce the RNG peripheral and its main features.
  • List the software frameworks and drivers managing the peripheral.
  • Explain how to configure the peripheral.
The RNG peripheral is used to provide 32-bit random numbers.
Refer to the wiki article Hardware random overview to learn more on the possible usages of this peripheral.
3.1.1. On STM32MP13x lines More info.png[edit | edit source]
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Security RNG RNG Required for DPA peripheral protection
3.1.2. On STM32MP15x lines More info.png[edit | edit source]
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Security RNG RNG1
3.1.3. On STM32MP21x lines More info.png[edit | edit source]
3.1.3.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Security RNG RNG1
RNG2 RNG2 must be started to generate the DDR encryption key
3.1.3.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Security RNG RNG1
3.1.4. On STM32MP23x lines More info.png[edit | edit source]
3.1.4.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Security RNG RNG
3.1.4.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Security RNG RNG
3.1.5. On STM32MP25x lines More info.png[edit | edit source]
3.1.5.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Security RNG RNG
3.1.5.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Security RNG RNG
If the Arm® Cortex®-A processor hardware RNG peripheral is assigned to OP-TEE, then the Linux kernel can request random numbers through the hardware random framework, which is interfaced with the OP-TEE RNG Linux driver .
If the Arm® Cortex®-A processor hardware RNG peripheral is assigned to the Linux kernel, then the Linux kernel can access it through the hardware random framework, which is interfaced with the Linux RNG driver .
nonsecure
Security RNG RNG Assignment (single choice)
nonsecure
Cortex-M4
Security RNG RNG1 Assignment (single choice)
RNG2
3.2.3. On STM32MP21x lines More info.png[edit | edit source]
3.2.3.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security RNG RNG1 OP-TEE
RNG2 OP-TEE
3.2.3.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
RNG2 OP-TEE
3.2.4. On STM32MP23x lines More info.png[edit | edit source]
3.2.4.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security RNG RNG OP-TEE
3.2.4.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.5. On STM32MP25x lines More info.png[edit | edit source]
3.2.5.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
3.2.5.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Below are listed the software frameworks and drivers managing the RNG peripheral for the embedded software components listed in the above tables.
  • Partial device trees (pin control and clock tree) generation for the OpenSTLinux software components.
This configuration is done in OP-TEE through the device tree.
For more information, refer to the wiki article RNG device tree configuration.
