- briefly introduce the TIM peripheral and its main features,
The TIM peripheral is a multi-channel timer unit, available in various configurations, depending on the instance used. There are basically following categories: advanced-control timers, general-purpose timers and basic timers.
The TIM can provide: PWM with complementary output and dead-time insertion, break detection, input capture[1], quadrature encoder[2] interface (typically used for rotary encoders), trigger source for other internal peripherals like: ADC[3], DFSDM[4]. The full list can be found in Peripherals Interconnect matrix in the reference manual.
The TIM peripheral is available in different configurations, depending on the selected instance :
| TIM type | TIM instances | Independent Channels | PWM | External event counter Trigger source |
Quadrature encoder |
| advanced-control timers | TIM1/TIM8 | 6 | |||
| general-purpose timers | TIM2/TIM3/TIM4/TIM5 | 4 | |||
| TIM12 | 2 | ||||
| TIM13/TIM14 | 1 | ||||
| TIM15 | 2 | ||||
| TIM16/TIM17 | 1 | ||||
| basic timers | TIM6/TIM7 |
| Compare to TIM12, TIM13 and TIM14, the configuration of TIM15, TIM16 and TIM17 brings some features that are very useful for motor control (like break function, DMA burst mode control, complementary output with dead-time insertion, ...) |
2.1. Additional instances to STM32MP2 series[edit | edit source]
| general-purpose timers | TIM10/TIM11 | 1 |
2.1.1. Additional instances to STM32MP25x lines
| advanced-control timers | TIM20 | 6 |
3.1.1. On STM32MP13x lines
Click on
to expand or collapse the legend...
- ⬚ means that the peripheral can be assigned to the given boot time context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given boot time context and that the peripheral is mandatory for the OpenSTLinux BSP.
| Domain | Peripheral | Boot time allocation | Comment | |||
| Instance | Cortex-A7 secure (ROM code) |
Cortex-A7 secure (TF-A BL2) |
Cortex-A7 nonsecure (U-Boot) | |||
| Core/Timers | TIM | TIMx (x = 1 to 8, APB2 group) |
| TIMx (x = 2 to 7, APB1 group) |
| TIMx (x = 12 to 17, APB6 group) |
3.1.2. On STM32MP15x lines
Click on
| Core/Timers | TIM | TIMx (x = 2 to 7, 12, 13, 14. APB1 group) | ☐ | |||
| TIMx (x = 1, 8, 15, 16, 17. APB2 group) | ☐ | |||||
3.1.3. On STM32MP21x lines
and STM32MP23x lines
3.1.3.1. For A35-TD flavor
Click on
| Instance | Cortex-A35 secure (ROM code) |
Cortex-A35 nonsecure (U-Boot) | |||
| Core/Timers | TIM | TIMx (x = 1 to 8, 10 to 17) | ⬚ | ☐ | ||
3.1.3.2. For M33-TD flavor
Click on
| Domain | Peripheral | Boot time allocation | Comment | ||||
Cortex-M33 secure (MCUboot) | |||
| Core/Timers | TIM | TIMx (x = 1 to 8, 10 to 17) | ⬚ | ☐ | ⬚ | ||
3.1.4. On STM32MP25x lines
3.1.4.1. For A35-TD flavor
Click on
| Core/Timers | TIM | TIMx (x = 1 to 8, 10 to 17, 20) | ⬚ | ☐ | ||
3.1.4.2. For M33-TD flavor
Click on
| Core/Timers | TIM | TIMx (x = 1 to 8, 10 to 17, 20) | ⬚ | ☐ | ⬚ | ||
3.2.1. On STM32MP13x lines
TIM12 and/or TIM15 can be allocated to the Arm® Cortex®-A7 secure core to be controlled in the secure monitor (OP-TEE).
TIM13, TIM14, TIM16 and TIM17 can also be allocated to the Arm® Cortex®-A7 secure context, but it is not supported yet by OpenSTLinux.
| RCC[5] owns one prescaler per TIM group corresponding to APB1, APB2 and APB6 buses: TIMG1PRE, TIMG2PRE and TIMG3PRE, respectively. TIMG3PRE is securable in RCC. The allocation to Cortex-A7 contexts should ideally be done on a per group basis to get independent clocking setup on each side, this is why the TIM instances groups are shown in the summary table below. |
Click on
- ⬚ means that the peripheral can be assigned to the given runtime context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given runtime context and that the peripheral is mandatory for the OpenSTLinux BSP.
| Domain | Peripheral | Runtime allocation | Comment | ||
| Instance | Cortex-A7 secure (OP-TEE) |
Cortex-A7 nonsecure (Linux) | |||
| Core/Timers | TIM | TIM1 (APB2 group) | ☐ | ||
| TIM2 (APB1 group) | ☐ | ||||
| TIM3 (APB1 group) | ☐ | ||||
| TIM4 (APB1 group) | ☐ | ||||
| TIM5 (APB1 group) | ☐ | ||||
| TIM6 (APB1 group) | ☐ | ||||
| TIM7 (APB1 group) | ☐ | ||||
| TIM8 (APB2 group) | ☐ | ||||
| TIM12 (APB6 group) | ☐ | ☐ | Assignment (single choice) TIM12 or TIM15 can be used for HSI/CSI calibration[6] | ||
| TIM13 (APB6 group) | ☐ | ☐ | Assignment (single choice) | ||
| TIM14 (APB6 group) | ☐ | ☐ | Assignment (single choice) | ||
| TIM15 (APB6 group) | ☐ | ☐ | Assignment (single choice) TIM12 or TIM15 can be used for HSI/CSI calibration[6] | ||
| TIM16 (APB6 group) | ☐ | ☐ | Assignment (single choice) | ||
| TIM17 (APB6 group) | ☐ | ☐ | Assignment (single choice) | ||
3.2.2. On STM32MP15x lines
TIM12 and/or TIM15 can be allocated to the Arm® Cortex®-A7 secure core to be controlled in the secure monitor (TF-A or OP-TEE).
| RCC[5] owns one prescaler per TIM group corresponding to APB1 and APB2 buses: TIMG1PRE and TIMG2PRE, respectively. The allocation to Cortex-A7 or the Cortex-M4 should ideally be done on a per group basis to get independent clocking setup on each side, this is why the TIM instances groups are shown in the summary table below. |
Click on
| Domain | Peripheral | Runtime allocation | Comment | |||
Cortex-M4 (STM32Cube) | |||
| Core/Timers | TIM | TIM1 (APB2 group) | ☐ | ☐ | Assignment (single choice) | |
| TIM2 (APB1 group) | ☐ | ☐ | Assignment (single choice) | |||
| TIM3 (APB1 group) | ☐ | ☐ | Assignment (single choice) | |||
| TIM4 (APB1 group) | ☐ | ☐ | Assignment (single choice) | |||
| TIM5 (APB1 group) | ☐ | ☐ | Assignment (single choice) | |||
| TIM6 (APB1 group) | ☐ | ☐ | Assignment (single choice) | |||
| TIM7 (APB1 group) | ☐ | ☐ | Assignment (single choice) | |||
| TIM8 (APB2 group) | ☐ | ☐ | Assignment (single choice) | |||
| TIM12 (APB1 group) | ☐ | ☐ | ☐ | Assignment (single choice) TIM12 or TIM15 can be used for HSI/CSI calibration[6] | ||
| TIM13 (APB1 group) | ☐ | ☐ | Assignment (single choice) | |||
| TIM14 (APB1 group) | ☐ | ☐ | Assignment (single choice) | |||
| TIM15 (APB2 group) | ☐ | ☐ | ☐ | Assignment (single choice) TIM12 or TIM15 can be used for HSI/CSI calibration[6] | ||
| TIM16 (APB2 group) | ☐ | ☐ | Assignment (single choice) | |||
| TIM17 (APB2 group) | ☐ | ☐ | Assignment (single choice) | |||
3.2.3. On STM32MP21x lines
The tables below are applicable to any TD flavor (A35-TD or M33-TD)
Click on
The present chapter describes STMicroelectronics recommendations or choice of implementation. Additional possibilities might be described in STM32MP21 reference manuals and in STM32MP23 reference manuals.
| Domain | Peripheral | Runtime allocation | Comment | ||||
| Instance | Cortex-A35 secure (OP-TEE / TF-A BL31) |
Cortex-A35 nonsecure (Linux) |
Cortex-M33 secure (TF-M) |
Cortex-M33 nonsecure (STM32Cube) | |||
| Core/Timers | TIM | TIMx (x = 1 to 8, 10 to 17) | ⬚OP-TEE | ☐ | ⬚ | ☐ | |
3.2.4. On STM32MP25x lines
Click on
| Domain | Peripheral | Runtime allocation | Comment | |||||
Cortex-M0+ (STM32Cube) | |||
| Core/Timers | TIM | TIMx (x = 1 to 8, 10 to 17, 20) | ⬚OP-TEE | ☐ | ⬚ | ☐ | ||
Below are listed the software frameworks and drivers managing the TIM peripheral for the embedded software components listed in the above tables.
- Linux®: PWM, the IIO, and the Counter frameworks
- OP-TEE: OP-TEE TIM driver , to perform HSI and CSI calibrations[6] in RCC
- U-Boot: PWM driver , typically used for a PWM backlight
- STM32Cube: HAL TIM driver
For Linux kernel configuration, please refer to TIM device tree configuration and TIM_OpenSTLinux_drivers articles.
STM32 cross-series timer overview[7] application note.
