BSEC internal peripheral
  • briefly introduce the BSEC peripheral and its main features,
The BSEC peripheral is used to control an OTP (one time programmable) fuse box, used for on-chip non-volatile storage for device configuration and security parameters.
The BSEC is configured at boot time to set up platform security.
Domain Peripheral Boot time allocation Comment
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Security BSEC BSEC
3.1.2.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Security BSEC BSEC
3.1.2.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Security BSEC BSEC
3.2.1. On STM32MP13x lines [edit | edit source]
nonsecure
Security BSEC BSEC
3.2.2. On STM32MP15x lines [edit | edit source]
nonsecure
Cortex-M4
Security BSEC BSEC Cortex-M4 can read BSEC shadow register (BSEC_OTP_DATAx) to read a lower OTP value
3.2.3. On STM32MP21x lines  and STM32MP23x lines [edit | edit source]
3.2.3.1. For A35-TD flavor [edit | edit source]
The present chapter describes STMicroelectronics recommendations or choice of implementation. Additional possibilities might be described in STM32MP21 reference manuals and in STM32MP23 reference manuals.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security BSEC BSEC OP-TEE
TF-A BL31
3.2.3.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security BSEC BSEC
3.2.4. On STM32MP25x lines [edit | edit source]
3.2.4.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
TF-A BL31
3.2.4.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Security BSEC BSEC
Below are listed the software frameworks and drivers managing the BSEC peripheral for the embedded software components listed in the above tables.
Information
  • BSEC lower OTP access can be made available to the Arm® Cortex®-A non-secure.
  • Upper OTP access can be managed as exceptions in BSEC device tree, used by
See also additional information in the BSEC device tree configuration article.
