Ethernet switch device tree configuration
This article explains how to configure the Ethernet switch when it is assigned to the Linux® OS. In this case, it is controlled by the Ethernet switch driver. The configuration is performed using the device tree mechanism. This provides a hardware description of the Ethernet switch peripheral used by the STM32/TTTech driver.
The Ethernet switch is a multifunction device.
Each function is represented by a separate binding document:
  • "Generic" Ethernet device tree bindings [1]
  • "Generic" Ethernet switch device tree bindings [2]
  • Specific STM32 DEIP device tree bindings[3]
  • Specific TTTech device tree bindings[4]
including DEIP Core Edge block
including ACM block
Ethernet peripheral nodes are located in
  • for STM32MP257 in stm32mp257.dtsi [5] file,
This is a set of properties that may not vary for a given STM32MP device, such as: interrupts, clocks, ...
  switch0: ttt-sw@4c000000 {
	#address-cells  = <1>;
	#size-cells     = <1>;
	compatible = "st,stm32-deip";
	clock-names = "ethsw-bus-clk", "ethsw-clk",
		      "ethswacmcfg-bus-clk", "ethswacmmsg-bus-clk";
	clocks = <&rcc CK_BUS_ETHSW>,
		 <&rcc CK_KER_ETHSW>,
		 <&rcc CK_BUS_ETHSWACMCFG>,
		 <&rcc CK_BUS_ETHSWACMMSG>;
	st,syscon = <&syscfg 0x3800>;
	ranges = <0x4c000000 0x4c000000 0x2000000>,
		 <0x4b000000 0x4b000000 0xc0000>;
	status = "disabled";
	deip_sw0: deip-sw@4c000000 {
		compatible =  "ttt,deip-sw";
		reg = <0x4c000000 0x2000000>;
		interrupts = <GIC_SPI 250 IRQ_TYPE_LEVEL_HIGH>;
	acm@4b000000 {
		compatible = "ttt,acm-4.0";
		reg = <0x4b000000 0x00400>,
		      <0x4b010000 0x10000>,
		      <0x4b030000 0x10000>,
		      <0x4b050000 0x10000>,
		      <0x4b060000 0x20000>,
		      <0x4b080000 0x40000>;
		reg-names = "CommonRegister",
			    "Bypass1",
			    "Bypass0",
			    "Redundancy",
			    "Scheduler",
			    "Messagebuffer";
		buffers = <32>;
		ptp_worker = <&deip_sw0>;
3.2. Ethernet DT configuration (board level)[edit | edit source]
These DT are same between U-Boot and kernel OS
The device tree board file (.dts) contains all hardware configurations related to board design. The DT node ("ethernet") must be updated to:
  • Enable the Ethernet block by setting status = "okay".
  • Configure the pins in use via pinctrl, through pinctrl-0 and pinctrl-names.
  • Configure Ethernet interface used phy-mode = "rgmii"., correspond to internal port sw0p1, port between GMAC IP and Switch. (do not change it)
3.2.1. DT configuration with rcc clock[edit | edit source]
 &eth1 {
    status = "okay";                                 /* enable eth1 */
    pinctrl-0 = <&eth1_mdio_pins_a>;    /* configure pinctrl mdio/mdc for eth1 */
    pinctrl-names = "default";
    phy-mode = "rgmii";                          /* configure ethernet phy mode for eth1 */
    st,eth-clk-sel;
    snps,ext-systime;
    fixed_link: fixed-link {                        /* configure ethernet fixed-link for eth1 */
    	speed = <1000>;                           /* configure ethernet max speed for fixed link */
    	full-duplex;
    mdio1 {
       #size-cells = <0>;
    	compatible = "snps,dwmac-mdio";
       phy1_eth1: ethernet-phy@4 {
    	      compatible = "ethernet-phy-id001c.c916",
    			     "ethernet-phy-ieee802.3-c22";
             realtek,eee-disable;
             reg = <4>;                                 /* configure ethernet phy 1 @ for eth1 */
       phy2_eth1: ethernet-phy@5 {
    	      reset-gpios =  <&gpioj 9 GPIO_ACTIVE_LOW>;
    	      reset-assert-us = <10000>;
    	      reset-deassert-us = <80000>;
    	      reg = <5>;                                /* configure ethernet phy 2 @ for eth1 */
 &switch0 {
   status = "okay";
   pinctrl-0 = <&eth1_rgmii_pins_a>, <&eth3_rgmii_pins_a>;   /* configure pinctrl for switch */
   phy-mode = "rgmii";
   st,ethsw-internal-125;
3.2.2. DT configuration with ETHx_CLK125 phy clock[edit | edit source]
To use the ETHx_CLK125 clock, we need to remove two properties :
  • st,eth-clk-sel : because it is used to set the rcc clock, so it must be removed from the dt
  • st,ethsw-internal-125 : because it acts on bit 2 of the register and is used to check which clock is used with
    • 0: External from ETH1_CLK125 pin
    • 1: Internal from ck_ker_ethsw
 &eth1 {
    snps,ext-systime;
    	full-duplex;
    mdio1 {
       #size-cells = <0>;
 &switch0 {
   status = "okay";
   phy-mode = "rgmii";
3.3. DT configuration example to transform ethernet switch to ethernet standalone at board level[edit | edit source]
The example below shows how to update devicetree to have eth1 as Ethernet standalone
3.3.1. For rcc clock[edit | edit source]
 &eth1 {
    pinctrl-0 = <&eth1_rgmii_pins_a &eth1_mdio_pins_a>;
    phy-mode = "rgmii-id";                          /* configure ethernet phy mode for eth1 */
    st,eth-clk-sel;
    snps,ext-systime;
    	speed = <1000>;
    	full-duplex;
    phy-handle = <&phy1_eth1>;
    mdio1 {
       #size-cells = <0>;
       compatible = "ethernet-phy-id001c.c916";
 &switch0 {
    status = "okay";
   phy-mode = "rgmii";
3.3.2. For ETHx_CLK125 phy clock[edit | edit source]
 &eth1 {
    snps,ext-systime;
    	speed = <1000>;
    	full-duplex;
    mdio1 {
       #size-cells = <0>;
 &switch0 {
    status = "okay";
   phy-mode = "rgmii";
4. How to configure Ethernet using CubeMX[edit | edit source]
