GTK demo launcher
1. STM32MP13x lines More info.png main menu[edit | edit source]
The main menu is composed of four demonstrations:
Main menu
2. STM32MP15x lines More info.png main menu[edit | edit source]
Main menu
3. STM32MP21x lines More info.png main menu[edit | edit source]
Main menu
4. STM32MP25x lines More info.png and STM32MP23x lines More info.png main menu[edit | edit source]
The main menu is composed of five demonstrations:
Main menu (picture is not contractual, given as example)
5. Demo launcher application[edit | edit source]
5.1. Netdata perf monitor[edit | edit source]
Netdata perf monitor (picture is not contractual, given as example)
5.2. Camera preview[edit | edit source]
A USB webcam can be used.
5.3. Video playback[edit | edit source]
Video Playback
5.4. Bluetooth® speaker[edit | edit source]
Bluetooth speaker
First use:
5.5. Artificial intelligence[edit | edit source]
Artificial Intelligence (picture is not contractual, given as example)
  • A: launches audio playback
  • C: launches camera preview
  • P: displays a picture
It is possible to start several instances of the same application (for example three audio playbacks at the same time). However this is not recommended.
5.6. 3D GPU[edit | edit source]
3D GPU (picture is not contractual, given as example)
5.7. Info menu[edit | edit source]
Info menu (picture is not contractual, given as example)
6. How to add a new demo application[edit | edit source]
  • must manage the QUIT/EXIT.
 /usr/local/demo/application/
 └── video
     ├── bin
     │   └── launch_video.sh
     └── pictures
/usr/local/demo/gtk-application/
 └── 02-video.yaml
The touch-event-gtk-player application is available to use gstreamer graph for camera preview or video playback. It allows playing a gstreamer graph, managing play/pause event via a simple click/touch and quitting/exiting playback via double click/touch.
/usr/local/demo/bin/touch-event-gtk-player --graph "<gstreamer graph>"
6.1. YAML application format[edit | edit source]
 Application:
    Name: <name of application>
    Icon: <icon of application>
    Type: <script|python>
    Board:
    Script:
        Exist:
    Python:
        Exist:
    Action:
Description of parameters:
Name
Description
Icon
Board
Type
Available types:
Script
Exist
Example
        Exist:
            File: /dev/video0
                    /dev/video0 doesn't exist
Python
Example
Exist
Example
        Exist:
            Command: hciconfig hci0 up
6.2. File tree[edit | edit source]
 ├── 000-netdata.yaml
 ├── 010-camera.yaml
 ├── 020-video.yaml
 ├── 030-3d_cube.yaml
 ├── 040-m4_ai.yaml
 └── 060-bluetooth_audio_output.yaml
 ├── 3d_cube
 │   ├── bin
 │   │   └── launch_cube_3D.sh
 │   └── pictures
 ├── bluetooth
 │   ├── bluetooth_audio.py
 │   ├── __init__.py
 │   ├── pictures
 │   └── wrap_blctl.py
 ├── camera
 │   ├── bin
 │   ├── pictures
 │   └── shaders
 ├── __init__.py
 ├── m4_ai
 │   ├── bin
 │   │   └── launch_AI.sh
 │   └── pictures
 ├── netdata
 │   ├── bin
 │   │   └── build_qrcode.sh
 │   ├── __init__.py
 │   ├── netdata.py
 │   └── pictures
 └── video
     ├── bin
     └── pictures
6.3. Examples of yaml application file[edit | edit source]
6.3.1. with Script, verification of device presence and board support[edit | edit source]
Application:
    Description: GPU with picture
    Board:
        NotList: stm32mp151
    Type: script
    Script:
        Exist:
            File: /dev/galcore
    Action:
6.3.2. with Script and verification of device presence[edit | edit source]
Application:
    Description: shader
    Board:
        List: all
    Type: script
    Script:
        Exist:
            File: /dev/video0
    Action:
6.3.3. with Python™ and verification via command[edit | edit source]
Application:
    Description: speaker
    Type: Python
    Board:
        List: stm32mp157 stm32mp153
    Python:
        Exist:
    Action:
6.4. Example of recipe to add an application[edit | edit source]
Example of recipe useful to add an application (demo-application-3d-cube) in the GTK demo launcher is available. It is available at:
chmod 0755 <script name>
 ├── 100-3d-cube.yaml
 ├── 101-3d-cube-shader.yaml
 ├── 110-3d-cube-video.yaml
 ├── 115-3d_cube_camera.yaml
 └──120-3d-cube-pictures-shader.yaml
 └── 3d-cube-extra
    ├── bin
    └── pictures
  • Associated recipe:
HOMEPAGE = "wiki.st.com"
LICENSE = "BSD-3-Clause"
SRC_URI = " \
    file://100-3d-cube.yaml \
do_configure[noexec] = "1"
do_compile[noexec] = "1"
do_install() {
    install -d ${D}${prefix}/local/demo/gtk-application
    # install yaml file
    install -m 0644 ${WORKDIR}/*.yaml ${D}${prefix}/local/demo/gtk-application/
    # install bin
    # install pictures
FILES_${PN} += "${prefix}/local/demo"
6.5. How to install demo application via packages[edit | edit source]
dpkg -l | grep demo-launcher
apt-get update
apt-get install demo-launcher
To add 3D application:
