- briefly introduce the DBGMCU peripheral and its main features,
On STM32MP15x lines
only, the DBGMCU peripheral is used by the boot chain and by OP-TEE to get the device ID and revision, to adapt their behavior accordingly. On other devices this information is obtained through SYSCFG.
The DBGMCU peripheral is also used to configure internal peripherals behavior when one of the available cores enters in debug mode.
During a debug session, the DBGMCU can be accessed via the debug access port (DAP) to configure the expected behavior on break, typically to get a watchdog (IWDG) frozen when the Cortex®-A enters in debug mode (via a breakpoint or JTAG break) and to avoid getting a watchdog reset during a debug session.
On STM32MP25x lines
only, each peripheral freeze bit inherit the permissions that are set on the same peripheral it controls.
3.1.1. On STM32MP13x lines
Click on
to expand or collapse the legend...
- ⬚ means that the peripheral can be assigned to the given boot time context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given boot time context and that the peripheral is mandatory for the OpenSTLinux BSP.
| Domain | Peripheral | Boot time allocation | Comment | |||
| Instance | Cortex-A7 secure (ROM code) |
Cortex-A7 secure (TF-A BL2) |
Cortex-A7 nonsecure (U-Boot) | |||
| Trace & Debug | DBGMCU | DBGMCU | ⬚ | ⬚ | ⬚ | |
3.1.2. On STM32MP15x lines
Click on
| Trace & Debug | DBGMCU | DBGMCU | ✓ | ☑ | ☑ | |
3.1.3. On STM32MP2 series[edit | edit source]
Click on
| Instance | Cortex-A35 secure (ROM code) |
Cortex-A35 nonsecure (U-Boot) | |||
3.2.1. On STM32MP13x lines
Click on
- ⬚ means that the peripheral can be assigned to the given runtime context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given runtime context and that the peripheral is mandatory for the OpenSTLinux BSP.
| Domain | Peripheral | Runtime allocation | Comment | ||
| Instance | Cortex-A7 secure (OP-TEE) |
Cortex-A7 nonsecure (Linux) | |||
| Trace & Debug | DBGMCU | DBGMCU | ⬚ | ⬚ | |
3.2.2. On STM32MP15x lines
Click on
| Domain | Peripheral | Runtime allocation | Comment | |||
Cortex-M4 (STM32Cube) | |||
| Trace & Debug | DBGMCU | DBGMCU | ☑ | ⬚ | ⬚ | |
3.2.3. On STM32MP21x lines
Click on
| Domain | Peripheral | Runtime allocation | Comment | ||||
| Instance | Cortex-A35 secure (OP-TEE / TF-A BL31) |
Cortex-A35 nonsecure (Linux) |
Cortex-M33 secure (TF-M) |
Cortex-M33 nonsecure (STM32Cube) | |||
| Trace & Debug | DBGMCU | DBGMCU | ⬚ | ⬚ | ⬚ | ⬚ | |
3.2.4. On STM32MP23x lines
Click on
3.2.5. On STM32MP25x lines
Click on
| Domain | Peripheral | Runtime allocation | Comment | |||||
Cortex-M0+ (STM32Cube) | |||
| Trace & Debug | DBGMCU | DBGMCU | ⬚ | ⬚ | ⬚ | ⬚ | ⬚ | |
There is no software dedicated to the DBGMCU internal peripheral delivered with STM32MPU ecosystem. Nevertheless, debuggers like STM32CubeIDE and OpenOCD can use the DBGMCU to freeze DMA and timer execution during step by step debugging.
