DDRCTRL and DDRPHYC internal peripherals
  • briefly introduce the DDRCTRL and DDRPHYC peripherals and their main features,
  • list the software frameworks and drivers managing the peripherals,
  • explain how to configure the peripherals.
The DDRCTRL and DDRPHYC peripherals are used to configure the physical interface to the external DDR memory. Access to the DDR memory can be filtered via the TZC controller on STM32MP1 series or via RISAF on STM32MP2 series.
Notice that it is possible to perform DDR bandwidth measurement thanks to the DDRPERFM internal peripheral.
The DDRCTRL and DDRPHYC peripherals are kept secure and used by the FSBL to initialize the access to the DDR where it loads the SSBL (U-Boot) for execution.
STMicroelectronics wishes to make the DDR memory configuration as easy as possible, for this reason a dedicated application note has been published by series (for STM32MP1 series [1] and for STM32MP2 series[2]) and a DDR tuning function is available in STM32CubeMX tool in order to generate the device tree configuration that is given to the FSBL to perform this initialization.
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Core/RAM DDRCTRL DDR
3.1.2.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Core/RAM DDRCTRL & DDRPHYC DDR Assignment is controlled by the RCC RIF 104 resource that also include the PLL2 control.
3.1.2.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
The DDRCTRL and DDRPHYC peripherals are accessed at runtime by the secure world of the cold boot CPU (see the Boot chain overview for details) to put the DDR in self-refresh state before going into Stop or Standby low power mode:
  • On STM32MP13x lines More info.png, OP-TEE is default located in DDR and it jumps into TF-A BL2 resident code in SYSRAM to configure the DDRCTRL and DDRPHYC
  • On STM32MP15x lines More info.png, OP-TEE is either located in SYSRAM (with CFG_STM32MP1_OPTEE_IN_SYSRAM=y, so it embeds the services to configure the DDRCTRL and DDRPHYC) or in DDR (see previous STM32MP13x lines More info.png case)
  • On STM32MP2 series,
    • for A35-TD flavor More info green.png: TF-A BL31 secure monitor is running in SYSRAM and configure the DDRCTRL and DDRPHYC after low power request
    • for M33-TD flavor More info green.png: the low power firmware is running in RETRAM and configure the DDRCTRL and DDRPHYC
On Standby exit, the ROM code loads the FSBL-A that again configures the DDRCTRL and DDRPHYC before proceeding with the wake-up procedure or for M33-TD flavor More info green.png jump in the RETRAM low power firmware.
DDR memory access is controlled by:
  • TZC controller on STM32MP1 series
  • RISAF on STM32MP2 series
nonsecure
nonsecure
Cortex-M4
3.2.3. On STM32MP21x lines More info.png and STM32MP23x lines More info.png[edit | edit source]
3.2.3.1. For A35-TD flavor More info green.png[edit | edit source]
The present chapter describes STMicroelectronics recommendations or choice of implementation. Additional possibilities might be described in STM32MP21 reference manuals and in STM32MP23 reference manuals.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core/RAM DDRCTRL & DDRPHYC DDR OP-TEE
TF-A BL31
3.2.3.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.4. On STM32MP25x lines More info.png[edit | edit source]
3.2.4.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
TF-A BL31
3.2.4.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Below are listed the software frameworks and drivers managing the DDRCTRL and DDRPHYC peripherals for the embedded software components (mainly low power sequences, initialization is always handled by TF-A BL2).
4.1. On STM32MP13x lines More info.png[edit | edit source]
4.2. On STM32MP15x lines More info.png[edit | edit source]
4.3. On STM32MP2 series[edit | edit source]
The DDRCTRL and DDRPHYC device tree configuration is generated via STM32CubeMX tool, according to the DDR characteristics (type, size, frequency, speed grade). This configuration is applied during boot time by the FSBL (see boot chain overview).
