This article aims to give the following information:
- How to use the X-LINUX-QT Developer Package to build Qt applications for the STM32 microprocessor series.
Check detailed prerequisites here.
2. Update the SDK environment for CMake[edit | edit source]
The OE_CMAKE_TOOLCHAIN_FILE variable needs to be set to allow building CMake projects with the installed SDK |
Please follow the steps below if it is necessary to add the missing OE_CMAKE_TOOLCHAIN_FILE variable to the SDK configuration.
- Open the terminal and load the environment setup:
source /opt/st/stm32mp2/5.0.3-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06/environment-setup-cortexa35-ostl-linux
- Add the missing OE_CMAKE_TOOLCHAIN_FILE variable to the qt6 environment file:
echo "export OE_CMAKE_TOOLCHAIN_FILE=\"\$OECORE_NATIVE_SYSROOT/usr/lib/cmake/Qt6/qt.toolchain.cmake\"" >> $OECORE_NATIVE_SYSROOT/environment-setup.d/qt6.sh
3. Install the STM32CubeIDE[edit | edit source]
- Follow the instructions from here to know how to install and use the STM32CubeIDE.
4. Select the updated OpenSTLinux SDK by the X-LINUX-QT Developer Package.[edit | edit source]
- Follow the instructions from here to know how to install the STM32MPU OpenSTLinux Developper Package for the STM32CubeIDE.
- Select the updated STM32MPU OpenSTLinux Developper Package by the X-LINUX-QT Developer Package.
5. Download the demo example source code[edit | edit source]
https://github.com/KDABLabs/KDBoatDemo.git -b qt6mkdir -p /opt/st/demos/Qt cd /opt/st/demos/Qt git clone
6. Build the demo example[edit | edit source]
- Import the Project from STM32CubeIDE.
- Start a new STM32 CMake Project:
- Select Project with existing CMake sources:
- Fill the Project name and source directory.
- Project name = KDBoatDemo
- Source directory = /opt/st/demos/Qt/KDBoatDemo
- Configure the default toolchain.
- Select OpenSTLinux SDK for the Toolchain field.
- Select the installed OpenSTLinux SDK (openstlinux-6.1-yocto-mickledore-mpu-v24.06.26) for the Version field.
- Build the Project.
- Select the project from the list and press the Build button:
- Wait until the build is finished and make sure it is done successfully:
7. Deploy the demo example to your running board[edit | edit source]
- Copy the example's binary into your connected board:
cd /opt/st/demos/Qt
scp config_default/KDABBoatDemo root@192.168.7.1:/home/root/.
8. Run the demo example on the board[edit | edit source]
- Connect to the running board:
ssh root@192.168.7.1
- Run the demo's example (windowed mode):
./KDABBoatDemo
- Check the running demo example on the board's display:
- Run the demo's example (Full screen mode):
./KDABBoatDemo --fullscreen
