USB2PHY internal peripheral
  • briefly introduce the USB2PHY peripheral and its main features,
The USB2PHY peripheral is a block that contains a USB high-speed UTMI+ PHY. It makes the interface between:
  • the internal USB controllers (USBH and USB3DR),
  • the external USB physical lines (DP, DM).
The USB2PHY peripheral is connected to the following controllers:
SoC USB2PHY1 USB2PHY2
STM32MP21x lines More info.png USBH OTG
STM32MP23x lines More info.png USB3DR for USB2.0 speeds.
SoC USB2PHY Block diagram
3.1.1. On STM32MP21x lines More info.png[edit | edit source]
3.1.1.1. For A35-TD flavor More info green.png[edit | edit source]
One USB2PHY instance, that is, USB2PHY2, is a boot device that support Flash programming with STM32CubeProgrammer.
The USB2PHY2 instance is used by ROM code, FSBL and SSBL when using OTG in Device mode (DFU).
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
High speed interface USB2PHY USB2PHY1 USB2PHY1 can be used in U-boot by USBH with command line tools.
USB2PHY2 USB2PHY2 can be used by ROM code, FSBL and SSBL in DFU mode to support serial boot.
It can be used also in U-boot by OTG with command line tools.
3.1.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
USB2PHY2 USB2PHY2 can be used in U-boot by OTG with command line tools.
3.1.2. On STM32MP23x lines More info.png and STM32MP25x lines More info.png[edit | edit source]
3.1.2.1. For A35-TD flavor More info green.png[edit | edit source]
The USB2PHY2 instance is used by ROM code, FSBL and SSBL when using USB3DR in Device mode (DFU).
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
It can be used also in U-boot by USB3DR with command line tools.
3.1.2.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
USB2PHY2 USB2PHY2 can be used in U-boot by USB3DR with command line tools.
3.2.1. On STM32MP21x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
High speed interface USB2PHY USB2PHY1 OP-TEE
TF-A BL31
Allocation inherited from USBH
USB2PHY2 OP-TEE
TF-A BL31
Allocation inherited from OTG
3.2.2. On STM32MP23x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
TF-A BL31
USB2PHY2 OP-TEE
TF-A BL31
Allocation inherited from USB3DR
3.2.3. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
TF-A BL31
USB2PHY2 OP-TEE
TF-A BL31
Below are listed the software frameworks and drivers managing the USB2PHY peripheral for the embedded software components listed in the above tables.
For U-boot and Linux kernel configuration, please refer to USB2PHY device tree configuration.
