GPU internal peripheral
Applicable for STM32MP15x lines, STM32MP23x lines, STM32MP25x lines
  • briefly introduce the GPU peripheral and its main features,
The GPU peripheral is a dedicated graphics processing unit. It accelerates numerous 3D graphics applications such as graphical user interface (GUI), menu display or animations. It works together with an optimized software stack designed for industry-standard APIs and supporting AndroidTM and Linux® embedded development platforms (read the STM32 MPU reference manual [1] for more details).
2.1. On STM32MP15x lines More info.png[edit | edit source]
The GPU peripheral main API supports are:
  • OpenGL® ES 1.1 and 2.0
  • OpenVG® 1.1
  • EGL 1.4
2.2. On STM32MP23x lines More info.png and STM32MP25x lines More info.png[edit | edit source]
The GPU peripheral provides a powerful hardware acceleration means for all modern Graphic, but also Neural, and general parallel computing applications.
Main API are the same as on STM32MP15x lines More info.png, with the following extra ones:
  • OpenGL® ES 3.2.8 (backward compatible: OpenGL® ES 2.1 & OpenGL® ES 1.1)
  • Vulkan 1.3
  • OpenVG® 1.3
  • OpenCL® 3.0
  • OpenVX® 1.3
The GPU peripheral is not used at boot time.
3.2.1. On STM32MP15x lines More info.png[edit | edit source]
nonsecure
Cortex-M4
Visual GPU GPU
3.2.2. On STM32MP23x lines More info.png[edit | edit source]
The table below is applicable to any TD flavor (A35-TD or M33-TD) More info green.png.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Visual GPU GPU OP-TEE
3.2.3. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Below are listed the software frameworks and drivers managing the GPU peripheral for the embedded software components listed in the above tables.
  • Linux®: OpenGL® ES framework
Under construction.png Add a link to "GPU framework overview" article when available.
See also additional information in the GPU device tree configuration article for Linux®.
Please go through the articles belonging to the GPU category.
  1. STM32 MPU reference manuals for more details
