This article explains how to configure the DMA internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the Dmaengine overview.
The configuration is performed using the Device tree mechanism that provides a hardware description of the DMA internal peripheral, used by the STM32 DMA Linux driver and by the DMA framework.
- STM32 DMA peripheral
- and STM32 DMA client
The STM32MP1 DMA node is located
For example, at device level, the DMA is declared as follows:
dma2: dma@48001000 {
compatible = "st,stm32-dma";
reg = <0x48001000 0x400>;
interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&rcc DMA2>;
resets = <&rcc DMA2_R>;
#dma-cells = <4>;
st,mem2mem;
dma-requests = <8>;
dmas = <&mdma1 8 0x11 0x1200000a 0x48001008 0x00000020 1>,
<&mdma1 9 0x11 0x1200000a 0x48001008 0x00000800 1>,
<&mdma1 10 0x11 0x1200000a 0x48001008 0x00200000 1>,
<&mdma1 11 0x11 0x1200000a 0x48001008 0x08000000 1>,
<&mdma1 12 0x11 0x1200000a 0x4800100C 0x00000020 1>,
<&mdma1 13 0x11 0x1200000a 0x4800100C 0x00000800 1>,
<&mdma1 14 0x11 0x1200000a 0x4800100C 0x00200000 1>,
<&mdma1 15 0x11 0x1200000a 0x4800100C 0x08000000 1>;
dma-names = "ch0", "ch1", "ch2", "ch3", "ch4", "ch5", "ch6", "ch7";
Do not change the DMA device tree at board level.
