OTG internal peripheral
Applicable for STM32MP13x lines, STM32MP15x lines, STM32MP21x lines
  • briefly introduce the OTG peripheral and its main features,
The OTG peripheral is used to interconnect other systems with STM32 MPU devices, using USB standard.
The OTG peripheral is a USB Dual-Role Device (DRD) controller that supports both device and host functions.
OTG speeds supported HS (480 Mb/s) FS (12 Mb/s) LS (1.5 Mb/s)
Host mode Yes Yes Yes
Device mode Yes Yes
OTG supports the following PHY interfaces:
SoC OTG peripheral PHY interfaces
STM32MP13x lines  USBPHYC internal peripheral
STM32MP15x lines  USBPHYC internal peripheral
On-chip low or full-speed PHY
STM32MP21x lines  USB2PHY internal peripheral
The OTG peripheral is fully compliant with
  • On-The-Go and Embedded Host Supplement to the USB Revision 2.0 Specification[1], Revision 2.0, May 8, 2009
  • Universal Serial Bus Revision 2.0 Specification[2], Revision 2.0, April 27, 2000
  • USB 2.0 Link Power Management Addendum Engineering Change Notice to the USB 2.0 specification[3], July 16, 2007
  • USB 2.0 Transceiver Macrocell Interface (UTMI) Specification[4], Version 1.05, March 29, 2001
  • UTMI+ Specification[5], Revision 1.0, February 25, 2004
The OTG peripheral is used by ROM code, FSBL and SSBL in device mode (DFU) to support serial boot for flash programming with STM32CubeProgrammer.
Domain Peripheral Boot time allocation Comment
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
High speed interface OTG (USB OTG) OTG (USB OTG) The OTG can be used by ROM code, FSBL and SSBL in DFU mode to support serial boot.
It can be used also in U-Boot with command line tools.
3.1.2. On STM32MP21x lines [edit | edit source]
3.1.2.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
High speed interface OTG OTG The OTG can be used by ROM code, FSBL and SSBL in DFU mode to support serial boot.
3.1.2.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
High speed interface OTG OTG The OTG can be used by U-Boot with command line tools
3.2.1. On STM32MP13x lines [edit | edit source]
nonsecure
High speed interface OTG (USB OTG) OTG (USB OTG) Assignment (single choice)
3.2.2. On STM32MP15x lines [edit | edit source]
nonsecure
Cortex-M4
3.2.3. On STM32MP21x lines [edit | edit source]
The tables below are applicable to any TD flavor (A35-TD or M33-TD) .
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
High speed interface OTG OTG OP-TEE
Below are listed the software frameworks and drivers managing the OTG peripheral for the embedded software components listed in the above tables.
For Linux kernel configuration, please refer to OTG device tree configuration.
For U-Boot configuration, please refer to Configure USB OTG node in U-Boot.
