This article explains how to configure Bluetooth [1] when the peripheral (or peripheral associated to the framework) is assigned to the Linux® OS.
The configuration is performed using the device tree mechanism [2].
The Bluetooth companion chip chosen on our platform is a Cypress chip
- for STM32MP13x lines
and STM32MP15x lines
[3]
- for STM32MP25x lines
and STM32MP23x lines
[4]
- for STM32MP21x lines
[5]
2. Bluetooth DT bindings documentation[edit | edit source]
The Bluetooth[6] tree bindings are composed of:
- STM32 USART device tree bindings [7]
- The Cypress device, used as child node [8] of the host USART device to which the slave device is attached.
3. Bluetooth DT configuration[edit | edit source]
This hardware description is a combination of the STM32 microprocessor device tree files (.dtsi extension) and board device tree files (.dts extension). See the device tree for an explanation of the device tree file split.
3.1. Bluetooth DT configuration (STM32 level)[edit | edit source]
The USART peripheral node is located
in stm32mp131.dtsi [9] - for STM32MP15x lines
in stm32mp151.dtsi [10] - for STM32MP25x lines
in stm32mp251.dtsi [11] - for STM32MP23x lines
in stm32mp231.dtsi [12] - for STM32MP21x lines
in stm32mp211.dtsi [13]
This is a set of properties that may not vary for given STM32 device, such as: registers address, clock, reset... The USART DT configuration is explained in Serial TTY device tree configuration
3.2. Bluetooth DT configuration (board level)[edit | edit source]
&usart2 {
uart-has-rtscts; /* enable hardware flow control */
bluetooth { /* node of Bluetooth companion chip */
shutdown-gpios = <&gpioz 6 GPIO_ACTIVE_HIGH>; /* GPIO specifier, used to enable the BT module */
compatible = "brcm,bcm43438-bt";
max-speed = <3000000>;
Specific properties for USART:
- uart-has-rtscts; bool flag to enable hardware flow control
4. How to configure Bluetooth using CubeMX[edit | edit source]
- ↑ Bluetooth
- ↑ Device tree
- ↑ MURATA CYW4343W datasheet
- ↑ MURATA CYW43439 datasheet
- ↑ MURATA CYW4373 datasheet
- ↑ WLAN_and_Bluetooth_hardware_component
- ↑ Serial TTY device tree configuration
- ↑ Documentation/devicetree/bindings/net/broadcom-bluetooth.yaml
- ↑ stm32mp131.dtsi
- ↑ stm32mp151.dtsi
- ↑ stm32mp251.dtsi
- ↑ stm32mp231.dtsi
- ↑ stm32mp211.dtsi
