DSI internal peripheral
Applicable for STM32MP15x lines, STM32MP23x lines, STM32MP25x lines
  • briefly introduce the DSI peripheral and its main features,
The DSI peripheral implements all the protocol functions defined in the MIPI® Display Serial Interface (MIPI® DSI) specification. It provides an interface to communicate with a DSI-compliant display. The MIPI® DSI is part of a group of communication protocols defined by the MIPI® Alliance [1].
On STM32MP15x lines More info.png, the DSI peripheral supports:
  • up to 2 D-PHY data lanes.
On STM32MP23x lines More info.png and STM32MP25x lines More info.png, the DSI peripheral supports:
  • up to 4 D-PHY data lanes.
  • the RIF security architecture: The RISUP differentiates the access right of accesses performed toward the following RIF protected peripheral ID:
    • "DSI_CMN": DSI common registers for DSI-wrapper and DSI-Host
    • "DSI_TRIG": DSI Wrapper trigger-A to update a smart panel
    • "DSI_RD": DSI-Host read access to a smart panel
Even if some MIPI DSI modes are supported by the DSI internal peripheral, in practice:
  • software frameworks like U-Boot or Linux® kernel do not support all the possible modes.
  • hardware integration constraints such as support for all the clock values or the pll configurations make it difficult to use all possible modes.
Select a MIPI DSI panel or bridge supporting the DSI video burst mode [2] because this mode is supported by all software frameworks and is easier to fine tune. Please consider the following recommendations when selecting a MIPI DSI panel or bridge for your project:
  • Pixel data transmission
    • in DSI command mode: not supported by neither U-Boot nor Linux® kernel, use instead the DSI video burst mode.
    • in DSI video mode:
      • burst mode: supported
      • non-burst mode with sync events or pulses: supported with clock constraints to be considered [2].
  • Command transmission (initialization sequence, backlight...)
    • in DSI command mode: supported
      • burst mode: supported if there is enough time to send commands before or/and after pixel data [2].
      • non-burst mode with sync events or pulses: supported but there are timing constraints to be considered [2].
If non-burst mode has to be used for a specific MIPI DSI panel or bridge, check non-burst mode constraints.
The DSI is used at boot time for displaying a splash screen through the U-Boot framework.
3.1.1. On STM32MP15x lines More info.png[edit | edit source]
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Visual DSI DSI
3.1.2. On STM32MP23x lines More info.png and STM32MP25x lines More info.png[edit | edit source]
3.1.2.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Visual DSI Info.png DSI Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature
The below table shows the possible boot time allocations for the features of the DSI instance.
Feature Boot time allocation Info.png Comment
Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
DSI_CMN
DSI_RD
DSI_TRIG
3.1.2.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
DSI_CMN
DSI_RD
DSI_TRIG
3.2.1. On STM32MP15x lines More info.png[edit | edit source]
nonsecure
Cortex-M4
Visual DSI DSI
3.2.2. On STM32MP23x lines More info.png[edit | edit source]
The table below is applicable to any TD flavor (A35-TD or M33-TD) More info green.png.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Visual DSI Info.png DSI Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature
The below table shows the possible runtime allocations for the features of the DSI instance.
Feature Runtime allocation Info.png Comment
Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
DSI_CMN OP-TEE
DSI_RD OP-TEE
DSI_TRIG OP-TEE
3.2.3. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
DSI_CMN OP-TEE
DSI_RD OP-TEE
DSI_TRIG OP-TEE
Below are listed the software frameworks and drivers managing the DSI peripheral for the embedded software components listed in the above tables.
See also additional information in the DSI device tree configuration article for Linux®.
You may be interested in the following related articles:
Refer to the STM32 DSI application note (AN4860) [2] for a detailed description of the DSI peripheral and applicable use-cases.
6.1. Non-burst mode constraints[edit | edit source]
In MIPI® DSI video burst mode, the setting for the DSI peripheral's PLL is quite relaxed. The DSI peripheral can send out pixel data in bursts, at rate higher that the pixel clock frequency. The consumer of the pixel data (the MIPI DSI display panel or bridge) will internally re-sample such data to the correct clock frequency. This makes easy to configure the DSI in video burst mode.
In MIPI® DSI video non-burst mode, instead, the DSI peripheral must send out the pixel data at the exact pixel clock frequency required by the MIPI DSI display panel or bridge. But, the set of pixel clock frequencies allowed by the DSI peripheral is limited by:
  • the input frequency of the DSI peripheral's PLL (linked to the HSE oscillator on STM32MP15x lines More info.png or to a flexgen clock on STM32MP23x lines More info.png and STM32MP25x lines More info.png);
  • the programmability of the DSI peripheral's PLL;
  • the min and max frequency of the VCO of the DSI peripheral's PLL;
  • the selected bit per pixel.
6.1.1. On STM32MP15x lines More info.png[edit | edit source]
The following script dumps all the possible pixel clock frequencies allowed, that can be checked against the pixel clock frequency required by the MIPI DSI panel or bridge.
#!/bin/bash
hse=24000000
vcomin=1000000000
vcomax=2000000000
n_lanes=2
# 24 bpp
byte_per_pixel=3
for i in {1..7}; do
   for n in {10..125}; do
     vco=$(($hse*2*$n/$i))
     if [ $vco -lt $vcomin -o $vco -gt $vcomax ]; then
       continue
     fi
     for o in 1 2 4 8; do
       hs_clk=$(($hse*$n/($i*$o)))
       echo $(($hs_clk*$n_lanes/(8*$byte_per_pixel)))
     done
   done
done | sort -nu
If the required frequency is not listed, you can either:
  • check the spec or contact the vendor of the MIPI DSI panel or bridge to identify other pixel clock frequencies allowed;
  • consider using a different frequency for the HSE oscillator.
It is possible to change the value of the variables in the script to dump the pixel clock frequencies for different HSE oscillators. Please also check in ROM code overview the values of HSE oscillator's frequency accepted by the BootROM. By changing the HSE oscillator, the Clock device tree configuration in TF-A and OP-Tee device tree must be aligned too.
6.1.2. On STM32MP23x lines More info.png and STM32MP25x lines More info.png[edit | edit source]
The DSI internal peripheral and related clock programmability on STM32MP23x lines More info.png and STM32MP25x lines More info.png is good enough for supporting the MIPI® DSI video non-burst mode without modifying the HSE reference clock frequency.
