BKPSRAM internal memory
  • briefly introduce the BKPSRAM internal memory peripheral and its main features,
The BKPSRAM internal memory is located in the VSW power domain, allowing it to be supplied during Standby low power mode, or to be switched off.
  • STM32MP13x lines  BKPSRAM is 8 Kbytes wide.
  • STM32MP15x lines  BKPSRAM is 4 Kbytes wide.
  • STM32MP2 series BKPSRAM is 8 Kbytes wide.
On STM32MP1 series, BKPSRAM could be completely assigned to the different execution contexts thanks to ETZPC firewall.
On STM32MP2 series, BKPSRAM could be shared between the different execution contexts thanks to RISAF firewall.
BKPSRAM is protected by tamper detection circuit and is erased by hardware in case of tamper detection.
The BKPSRAM internal memory is not used during a cold boot or a wake up from Standby with DDR OFF.
The BKPSRAM internal memory is used by the runtime secure monitor (from the FSBL or the OP-TEE secure OS) during wake-up from Standby low power mode with the DDR in Self-Refresh mode. In that case, the BKPSRAM internal memory contains the secure context that has to be restored before jumping back to Linux execution, in DDR.
Domain Peripheral Boot time allocation Comment
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Core/RAM BKPSRAM BKPSRAM
The BKPSRAM is assigned thanks to RISAF1 configuration that allows sharing and splitting the memory into different regions. It must be done accordingly to the ecosystem usage.
For the OpenSTLinux embedded software:
3.2.1. On STM32MP13x lines [edit | edit source]
nonsecure
Core/RAM BKPSRAM BKPSRAM Assignment (single choice)
3.2.2. On STM32MP15x lines [edit | edit source]
nonsecure
Cortex-M4
3.2.3. On STM32MP21x lines [edit | edit source]
The tables below are applicable to any TD flavor (A35-TD or M33-TD) .
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core/RAM BKPSRAM BKPSRAM BL31
OP-TEE
Assignment thanks to RISAF1
The BKPSRAM can be assigned to the different execution contexts thanks to RISAF1 that allows sharing and splitting the memory into different regions. RISAF1 configuration shall be done accordingly to the ecosystem usage.
For OpenSTLinux embedded software, refer to BKPSRAM OpenSTLinux memory mapping.
3.2.4. On STM32MP23x lines [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
OP-TEE
3.2.5. On STM32MP25x lines [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
OP-TEE
4.1. STM32MP1 series[edit | edit source]
On STM32MP1 series, the BKPSRAM peripheral can be allocated to either:
  • the Arm® Cortex®-A7 secure to be used by the runtime secure monitor (from the FSBL or the OP-TEE secure OS) to save/restore the secure context before entering/after exiting Standby low power mode with DDR in Self-Refresh mode. Standby low power mode is reached thanks to PSCI [1] secure services (from the FSBL or OP-TEE secure monitor). This is the default assignment.
  • the Cortex-A7 non-secure to be used under Linux® as reserved memory, for instance.
Warning
Default OpenSTLinux embedded software delivery prevents to define BKPSRAM as non-secure. This requires to modify TF-A source code with one of the following strategies:
  • set BKPSRAM as non-secure and degrade low power modes support, removing Standby mode
  • manage on-the-fly secure/non-secure switch of the BKPSRAM in the secure monitor for sequential usage for Standby management and Linux kernel reserved memory
Thus, below are listed the software frameworks and drivers managing the BKPSRAM peripheral for the embedded software components listed in the above tables.
4.2. STM32MP2 series[edit | edit source]
  • partial device trees (pin control and clock tree) generation for the OpenSTLinux embedded software components,
