Arm Cortex-M0+
  • briefly introduce the Arm® Cortex®-M0+ (coprocessor) peripheral and its main features,
The Arm® Cortex®-M0+ (coprocessor) Arm® is a Armv6-M 32-bit processor. It is a very energy efficient processor dedicated to low power use cases. Among a wide range of features, it includes:
  • a 2-stage pipeline,
  • a memory protection unit (MPU),
  • Non-Maskable Interrupt (NMI),
  • Serial Wire Debug.
The Cortex-M0+ supports only a non-secure mode that define one hardware execution contexts, named Cortex-M0+ non-secure.
The Cortex-M0+ is present in the STM32MP25x lines More info.png, integrated in a dedicated power domain named D3. Its main usage is low power batch acquisition mode with Cortex-A35 and Cortex-M33 in low power mode or power off. The Cortex-M0+ can be controlled either by Cortex-A35 or by Cortex-M33. Once loaded and started, Cortex-M0+ can run independently from rest of the system.
Refer to the STM32 MPU reference manuals for the complete list of features, and to the software frameworks and drivers, introduced below, to see which features are implemented in the STM32MPU Embedded Software distribution.
3.1.1. On STM32MP25x lines More info.png[edit | edit source]
3.1.1.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Core/Processors Arm® Cortex®-M0+ (coprocessor) Arm® Cortex®-M0+
3.1.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Core/Processors Arm® Cortex®-M0+ (coprocessor) Arm® Cortex®-M0+ (coprocessor) OP-TEE
Below are listed the software frameworks and drivers managing the Arm® Cortex®-M0+ (coprocessor) for the embedded software components listed in the above tables.
  • The Cortex-M0+ runs applications developed using to the STM32CubeMP2 distribution package.
  • The Cortex-M0+ can be startup at runtime, with or without firmware authentication, using the remoteproc frameworks available in different components of the OpenSTLinux distribution:
  • The Cortex-M0+ operates as a coprocessor, either autonomously as any external microcontroller, or communicating with the other processors (Cortex-A35 or Cortex-M33) via the IPCC.
The Cortex-M0+ assignment can be done via the STM32CubeMX graphical tool (and manually completed if needed).
This tool also helps to configure two aspects:
  • Which Cortex-A35 or Cortex-M33 software component is in charge of Cortex-M0+ management
  • Which peripherals are assigned to Cortex-M0+
CubeMX allows generating:
  • partial device trees (pin control and clock tree and firewall configuration) for the OpenSTLinux software components,
Refer to the Arm website[1] for more detailed information on this core.
Refer to the How to use the Cortex-M0+ page for an example of the Cortex-M0+ usage in the STM32MPU Embedded Software distribution.
